Grease fittings
Old 05-24-2012, 06:03 PM
macguy's Avatar
macguy
macguy is offline
Grease fittings
Why no grease fittings on front suspension. Both ram and GM have zerk fittings on their HD models, so why doesn't Ford? How long do these ball joints last on rough roads and how expensive to replace.
Old 05-24-2012, 07:14 PM
ruschejj's Avatar
ruschejj
ruschejj is offline
There is 1 fitting on the u joint at the hub. Right where the front half shaft joins the hub.
Otherwise, I don't know enough to answer the rest of your post. I will say this though, I wouldn't compare our SD front suspensions to the competition.
Old 05-24-2012, 07:16 PM
shadowSVT's Avatar
shadowSVT
shadowSVT is offline
I'll go ahead and answer it - ours will still be on the road long after theirs with their zirc's are recycled.
Bitter ex-chevy owner speaking from experience.
Old 05-24-2012, 08:32 PM
macguy's Avatar
macguy
macguy is offline
Didn't the older models like you have prior to 2010 have zirk's? My Father has E series vans for his business all prior to 2010 and they all have zirk's.
Old 05-24-2012, 09:08 PM
longview1's Avatar
longview1
longview1 is offline
Negative. The only zerks in my 08 are in the front axle u joints like mentioned.
Old 05-24-2012, 10:42 PM
SavageNFS's Avatar
SavageNFS
SavageNFS is online now
Received 7,231 Likes on 2,257 Posts
Old 05-27-2012, 09:24 PM
07 F250 Aggie Mobile's Avatar
07 F250 Aggie Mobile is offline
Same thing on my 2007
Old 05-28-2012, 04:49 AM
macguy's Avatar
macguy
macguy is offline
How well does suspension hold up with mileage and rough roads? Did you have to replace any ball joints?
Old 05-28-2012, 07:02 AM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
Tuxedo Scorpion is offline
Originally Posted by SavageNFS
bet you wish that was aluminum too. or at least painted. lol. i know i wish mine were painted, and thought about it. but not worth takin all apart imo. now if i had an alignment shop and the skills to do it, be a different story
Old 05-28-2012, 07:04 AM
Tuxedo Scorpion
not sure how they hold up from personal experience, but i know 95% of the guys racing off road in baja and such all drive PSDs for their pit/tow vehicles.
i know there have been people that have had their ball joints and such replaced under warranty if your coverage goes that far
Old 05-28-2012, 09:39 AM
Painted Horse's Avatar
Painted Horse
Painted Horse is offline
Received 2,596 Likes on 737 Posts
Replacing Ball joints is a common repair on Ford Trucks, But it's usually out past the 100,000 mile point.
Two of the last GM trucks I bought needed new ball joints around 30,000 miles.
So I think the Fords hold up a lot better from my personal experience
Old 05-28-2012, 09:41 AM
Tuxedo Scorpion
maybe i can get em to replace them at 99,000 then
Old 05-28-2012, 07:49 PM
juneau92's Avatar
juneau92
juneau92 is offline
Okay so how often should we grease this one fitting? I know on my 08 GMC there were 11 fittings and it was recommended to grease them every 5000 miles.
I'm at 6000 now in my new Ford, so should I grease it? Thanks.
Old 05-28-2012, 09:04 PM
SavageNFS's Avatar
SavageNFS
I grease them every oil change. So for me, it's every 5000 miles.
Old 05-28-2012, 09:06 PM
Tuxedo Scorpion
Do they turn all the time or only in 4wd
Quick Reply: Grease fittings
