Retro Engine Program FE series engines
Old May 5, 2003 | 10:28 AM
gary534's Avatar
gary534
I wrote to Ford Motor Co and suggested that they introduce a Retro Engines Program to coincide with their 100th anniversary in 2003. As part of the program,I suggested that they offer five FE crate engines:a 432 CID DOHC,a 456 CID medium riser, high riser,and SOHC,and a 480 CID tunnel port. 432 CID specs:4.38 bore x 3.584 stroke,1.625 piston compression height,0.033 deck clearance, 6.72 con rod length ( 1.875 rod ratio ) ,10.17 block deck height.456 CID specs:4.38 bore x 3.784 stroke,1.625 piston compression height,0.031 deck clearance,6.622 con rod length ( 1.75 rod ratio ), 10.17 block deck height.480 CID specs:4.38 bore x 3.984 stroke,1.675 piston compression height, 0.029 deck clearance,6.474 con rod length ( 1.625 rod ratio ),10.17 block deck height.Engines feature forged pistons,billet or forged con rods with oil hole up the beam and 7\16 cap screw rod bolts, billet or forged cranks,cross-bolted mains,SOHC and DOHC have gear driven cams.I encourage any of you who want these engines to write to Ford.
Old May 5, 2003 | 12:10 PM
rusty70f100's Avatar
rusty70f100
Cool. What's the address? I would expect that if they did anything, they'd re-introduce the SOHC 427 crate engine, for people with cobra's. And then only if they still have the original tooling laying around somewhere. The bigger ones would be cool, though.
Old May 7, 2003 | 10:19 AM
gary534's Avatar
gary534
Ford Motor Company ; Customer Relationship Center ; P.O. Box 6248 ; Dearborn MI 48126 - Please be sure to include the " customer relationship center " part of the address , as the Postal Service has been closing some p o boxes due to 9-11,etc. Thank you very much for your interest and your reply , rusty70f100.
