85 351 w h.o. question
Old May 23, 2012 | 05:04 PM
im2tall33's Avatar
im2tall33
Ok i did search and did not find my answer if this has been covered before i am sorry..
What i am wanting to know is what model Holley carb came on this motor. Cfm, and such. I want to rebuild it soon and want to make sure i order everything correctly. Thank you for your help.
Old May 23, 2012 | 05:48 PM
ctubutis's Avatar
ctubutis
To get the "proper" rebuild kit, they are going to want the info on the tag. Does your carb still have a tag? It will look similar to this:
Old May 23, 2012 | 05:54 PM
Archion's Avatar
Archion
Veteran: Marine Corps
On that carb the numbers should be stamped into the air horn. It should be looking you in the face when you pull the air cleaner off.
Old May 23, 2012 | 05:55 PM
Old Hickory's Avatar
Old Hickory
If is the original carb, then it is a Motorcraft/Holley 4180 four barrel that is 600 cfm.
You can get a Holley kit that is available from Summit or a Motorcraft kit that you may
be able to get from a Ford dealer or off of e-bay. The Holley kit will be cheaper. I
would not use a kit that is not one of the above because of inferior parts that they use.
Old May 23, 2012 | 06:11 PM
im2tall33's Avatar
im2tall33
Hmm i have not noticed a tag like that. I will look tonight when i get home, also i can take pics of the carb. I f that will help
and thanks for the help guys i will see what i can find
Old May 23, 2012 | 06:14 PM
im2tall33's Avatar
im2tall33
these are the pics that i have right now..not sure if they will help at all.
Also i does have an electric choke on the side
Old May 23, 2012 | 06:17 PM
ctubutis's Avatar
ctubutis
That looks like an aftermarket carb, the factory variants don't have a big Holley on them like that.
Old May 23, 2012 | 06:23 PM
im2tall33's Avatar
im2tall33
Where might the model number be listed on it? do you have a guess as to which carb i do have?
If it is a "Big Carb" like you mentioned that may explain why i get such crummy mpg's lol
Old May 23, 2012 | 06:30 PM
ctubutis's Avatar
ctubutis
Remove that black, plastic ring (air cleaner riser) and look for numbers stamped into the air horn, I'd be looking on the top-right.
Hey, wait a minute here, buddy!
I said "big *Holley*" referring to the large letters on the front float bowl, not trying to refer to the carb as a whole.
There are better carb guys than me here, they can maybe identify it better than I can.
Old May 23, 2012 | 06:46 PM
im2tall33's Avatar
im2tall33
Thanks for the info man. and I know i had mentioned it to you before, but i am a complete noob when it comes to carbed motors..
Old May 23, 2012 | 08:52 PM
LARIAT 85's Avatar
LARIAT 85
That is definitely not the stock Motorcraft/Holley 4180 truck carburetor that your truck originally came with. The big "HOLLEY" letters and the lack of the carburetor vent on the fuel bowl for the connection to the charcoal canister is a dead give away.
It looks like an aftermarket Holley 4160 (600cfm) carburetor to me.
Old May 24, 2012 | 05:37 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Definitely not stock.
The 4180 has a fuel inlet with a 7/8-20 threaded housing for a plastic mesh fuel filter sock and a flare fitting to couple to a rigid metal fuel line.
The list number and build date is similar to this illustration of a 4150 from the Holley website.
Locating Holley Carb List Number
Old May 24, 2012 | 10:29 AM
im2tall33's Avatar
im2tall33
thanks for the help guys.. I couldnt go look at it last night since the heavens opened up and showered us like crazy. hopefully it will be nicer out tonight when i get off work.
Old May 29, 2012 | 05:50 PM
im2tall33's Avatar
im2tall33
bumping this so i can remember to post a pic up tomorrow of my model number lol
Old May 30, 2012 | 01:32 PM
im2tall33's Avatar
im2tall33
ok i finally was able to clean up the carb enough to see the numbers on it. Here is a pic of the numbers stamped on it, does anyone know what carb i have?
