For an engine that beefy, I wouldn't think so. What is your timing at since you swapped the cam? I know that in my hobby stock car that has comparable lift/duration our timing is at 36 advanced. That's idling at around 1100 rpms and the throttle response is excellent. You have to advance the timing quite a bit for a cam that radical..
EDIT: I'm assuming you're going for speed and not a tow truck. Also, I wouldn't advance the timing as much as my hobby stock. I only said that as an example that you might want to advance the timing a bit more than stock to get a little more pep out of her. I have mine at 12* BTDC. My cam isn't as radical as your so you may want to go to 14*.
Hey Country,
I doubt if its the carb. That motor is going to gulp gas and the 870 should not be to big for it, of course much depends on all of the other components present.
In this case, I would suspect the cam. The powerband is from 2500-6000, so you need to spool that beast up to 2500 rpm before the torque kicks in, and that is what gets that truck moving (especially with those 37 in tires). A cam with a lower rpm range may provide better take off for you.
What kind of intake do you have? Headers or stock manifold? All of those things can affect the torque curve and thus, takeoff, or lack thereof. I hope that helps in some small way. I am not an expert, by any means, but I did a lot of research when I built the 408 stroker for my project.
Hey Country,
I just checked your profile, and it says this thing has edelbrock intake, headers, and Nitrous?!! What's going on with that? Need more info.
I agree with the smaller carb idea.Try a 750 vac.sec. or try a heavier spring in the 870 sec vac. housing.That cam isn't too much.224 @.050 for a 466 is great.My flat tappet 554" 574" comp cams has 234@ .050 and my truck will fry the tires("32 w/3:50 ears) from a dig.Also I run a 3310 vac.sec 750 cfm.Had a 670 Street Avenger on an aluminum headed 357 sbf and always had fine tuning issues with it.I ve read neg. reviews from some top engine builders/tuners on 460ford.com,and can relate to some of the issues they have with them.Mainly the primary metering block is of poor design and causes problems.I've since replaced mine(Street Avenger) with a 1850 Holley and the truck runs much better.
This is a classic case of changing the personality of a engine that used to be a low revving low compression truck engine, into a higher rpm racing engine. Stick that thing it a mustang now, and it would fly. In a heavy truck, it has problems.
Your 4.56 gears are good, but the 37 inch tires are taking their advantage away. If you have more near stock size tires on it, it would make a big difference.
Hopefully the carb is vacuum secondary, and hopefully your intake is dual plane. If both are true, then the cam may be the only thing you can do to bring the power back down into the lower rpms so you can use it.
Hey Country,
Ron
I have the Wieand Stealth intake (low rise, dual plane) and Hedman headers to 2-1/2 single tube exhaust through a Flow Master muffler.
I corrected my profile. I do not have the Edelbrock manifold (that was several years ago).
Hey Country,
Nice looking motor, by the way. :-)
You can never have enough power - you just run out of money at some point.
Yeah - it is dual plane intake with vacuum secondaries on the Holley. Also vacuum advance on the distributor.
Thank for your reply.
I need to go back out and check the timing. I think it is around 8 BTDC with full advance at 28 degrees. I haven't looked in a while and I forget where it ended up.
My vacuum at idle is around 10-12.
Hey, that sounds awfully conservative on the timing. Disconnect the vacuum advance and plug it off for now. Then advance the timing to about 10 to 14 degrees, even higher if it will take it. I believe you will notice a big difference. Advance it some, then find a big hill and nail it in high gear and see if the engine rattles. If it doesn't, advance it some more. Keep going till the engine rattles, then back it down a couple of degrees. After that, let it sit for 5 minutes and then see if it will crank over. If it struggles to crank, then back the timing down a little bit more till it turns over easily when it's hot.
You have to set your timing by ear, since you have changed everything around. After all this, you might need to then get an adjustable vacuum advance. If it pings and runs terrible when the vacuum line is hooked back up, you have too much advance with the vacuum , and I would leave it unhooked rather than back the timing down even more.
You should see your vacuum go up as well when you increase the timing.
How much have you messed with the idle mixture screws on the carb? The best thing I ever did on my truck was have the vacuum gauge hooked up, slowly turn the mixture screws out until you get the highest possible vacuum, then turn them back in until the vacuum drops a half a mark. Then do the other side the same way.
