shift points
Old May 22, 2012 | 07:33 PM
RIKIL's Avatar
RIKIL
shift points
Anyone happen to know the shift points( RPM and MPH) for an E4OD in a 92 F150 4x4?
Old May 22, 2012 | 07:51 PM
Midnite1987's Avatar
Midnite1987
Depends how far you push the gas pedal I do believe
Old May 24, 2012 | 08:13 PM
RIKIL's Avatar
RIKIL
Now I understand that you are right on. I was asking because I have a program I can use to change the shift points. I got a file from the website today that talks about how it works and it says that the shifting is directly related to the input from the TPS, same as gas pedal IMHO.
Thanks.
Old May 24, 2012 | 09:54 PM
rla2005's Avatar
rla2005
My 1992 4x4 F350 w/5.8L engine and E4OD shifts @4000 RPM with the throttle on the mat.
Old May 24, 2012 | 10:09 PM
RIKIL's Avatar
RIKIL
Ummmm...you have only 2 gears?
Old May 25, 2012 | 12:03 AM
Lead Head's Avatar
Lead Head
Shifts points are done by a table mapped out for each shift (ex, there is a table for the 1-2, 2-3, 3-2, etc..). The table references TPS (throttle position, which directly corresponds to pedal position ) vs MPH at a few different points
However when WOT, the computer ignores those tables. For WOT shifts, there are 3 fixed values the computer looks at. WOT 1-2 RPM, WOT 2-3 RPM, and WOT 3-4 RPM.
For the 5.8 and 460, those shifts are set right around 4000 RPM, the 5.0 WOT shifts are set a little higher. The 4.9 shifts are probably a bit lower.
Old May 25, 2012 | 12:36 AM
garlindethfury's Avatar
garlindethfury
I drive a 2001 F450 wrecker for work with V10 and an E4OD, and when I bury the pedal to the mat it can shift as high as 5500. Pulling a load up hill I have seen just shy of 6000.
Old May 25, 2012 | 12:50 AM
Lead Head's Avatar
Lead Head
Revlimit on the V10 is ~5200 RPM.
Old May 25, 2012 | 12:56 AM
garlindethfury
Yeah well you have to remember this I am looking at the tack and who knows if it is a little off. Also the truck itself empty with a full tank of gas is just over 13000 lbs you put something behind it and sometimes you have to rev the nuts off it to make some hills. Plus there is just something about the sound of a v10 singing at hi rpm's it is intoxicating...
DMANDIE
Jan 21, 2018 05:27 PM
fhafer
Dec 14, 2015 04:03 PM
austinramsay
Oct 18, 2011 09:28 PM
Slowroll90
May 13, 2011 11:28 PM
6CylBill
Oct 18, 2009 12:35 PM
