KB-silvolite pistons
Old May 4, 2003 | 11:22 PM
gregdatech's Avatar
gregdatech
Anyone use these in 460's? In particular #1143c. Im going to be using D0VE-A heads and a 10.300" deck block, and am wanting to keep compression between 9.4-10.5:1 with good quench. good? no good?
Old May 5, 2003 | 06:58 PM
georgedavila's Avatar
georgedavila
Not personally, but I've heard no complaints from others who have used KBs. It is important to use KB's ring gap specs.
http://www.kb-silvolite.com/
Old May 6, 2003 | 06:06 AM
DeenHylton's Avatar
DeenHylton
I agree with George, from what I've read on other forms hypereutectic pistons are actually stronger (or at least as strong as) forged pistons. What they can't tolerate is a lot of detonation as they are more brittle than forged. A couple of years ago I called tech at KB and they told me they had sponsored a 1,500 HP blown alcohol car that had run their pistons. I'm currently running them in my Vette which has a small blower and regularly sees a 210 HP shot of nitrous with no problems so far. I do run AV gas and pull out 6 degrees of timing (for nitrous) though to keep it from detonating.
Like George says...you must follow their ring-gap recommendations or you WILL break a ring-land.
I'd say if you have the extra money buy forged for that extra insurance and peace of mind, but KB's will do if you can keep that detonation demon from "knocking" on your door...
Deen
Old May 6, 2003 | 08:13 AM
gregdatech's Avatar
gregdatech
Think Ill stick with the 2404F's then. While crunching numbers, with compression height and rod length etc, I come up with .014" below the top of the deck for the piston, plus whatever the headgasket is. Wont this be a tad large for good quench? Curious if the block can have that much milled off to get it where I want?
moosey78
Modular V10 (6.8l)
116
Mar 21, 2024 04:20 PM
CP Louie
Oct 24, 2017 05:45 PM
BGLeRoy
Modular V10 (6.8l)
May 29, 2015 10:38 AM
Y2K1TON
1978 - 1996 Big Bronco
Feb 14, 2015 09:39 AM
AMSContr
Oct 15, 2013 05:07 AM
