leaks downhill
Old May 21, 2012 | 05:56 PM
The Blue mule's Avatar
The Blue mule
leaks downhill
'77 460 with c-6. Trans leaks fluid only when parked downhill, and very minimal, if at all, when parked up-hill. Anyone know what seal inside trans. is responsible for this?
thankyou
Old May 21, 2012 | 06:18 PM
73M6M's Avatar
73M6M
The leak could be on the exterior - Like the speedometer cable, filler tube or modulator. Have you checked any of these?
Old May 21, 2012 | 06:26 PM
The Blue mule
...yes,i've checked everthing fromrad to trans.,all lines,and everything that enters or exits the trans.,and it's all dry.Leak is definitly internal,as it only drips from centre of insp. plate/bell housing.
Old May 21, 2012 | 06:28 PM
critterf1's Avatar
critterf1
Torque convertor seal.
Old May 21, 2012 | 06:43 PM
The Blue mule
....thanks critter...guess i'll get after it.
Old May 21, 2012 | 08:23 PM
kenny nunez's Avatar
kenny nunez
oil leak
Blue Mule, In addition to the front pump seal make sure that the front pump "O" ring is not leaking . C6's are real bad about front pump leaks. Standing the transmisson vertically on the tail shaft is the best way to change the front pump "O"ring, the replacement rings are a little bit thicker because they were notorius for leaking.
Kenny Nunez
Old May 22, 2012 | 01:40 PM
The Blue mule
i put some wynn's trans. stop leak,and now it leaks more probably because the wynn's has dis-intergrated what was left of the leaking seals...question is: are all the other seals in the tranny wrecked now also?...is this tranny worth pulling out to replace the 2 suspect seals,or is it a basket case and get a reman tranny. ?
Old May 22, 2012 | 01:49 PM
77f-250's Avatar
77f-250
the seal was probably bad and the goo just finished it off if the other seals aren't bad id just pull it and replace the seal. If not take it to a professional transmission re builder and just redo it.
Old May 23, 2012 | 01:06 PM
Blue Oval Farm Boy's Avatar
Blue Oval Farm Boy
If you are thinking of getting your tranny rebuilt I have a rebuilt one on the bench. Not sure what I would need dollar wise but I could find out if you are interested.
David.
EDsurvivor
Jul 30, 2018 09:32 PM
cdev
Feb 15, 2016 07:38 PM
bla614
1997 - 2003 F150
Jul 7, 2013 10:33 AM
geoaigel
Aug 18, 2011 05:42 AM
dcsmith
Sep 30, 2007 02:15 PM
