Pre vs post 86 302 question
Old May 4, 2003 | 10:03 PM
cybercoyote's Avatar
cybercoyote
Question Pre vs post 86 302 question
I'm building up a 302 for my 67 F-100. The plan is to put an EFI system off of a HO mustang. I recently got my hands on an engine, but it's out of a 1973 bronco. Will a 90 EFI system work on a 73 block?
And what is the diffrence between the 85 and earlier blocks as opposed to the 86 and newer blocks? That seems to be the change date...
Can anyone help?
Old May 5, 2003 | 12:18 PM
90f150moneypit's Avatar
90f150moneypit
Not sure when they went to the roller blocks (90's), but I believe the Mustangs had them earlier than the trucks.
I also believe the '86 block is the only year that differs because it had flat top pistons, no others did. Not sure of any other changes.
Sorry I couldn't be of any more help.
Old May 6, 2003 | 10:58 AM
red_rocket's Avatar
red_rocket
yes the efi system will work on any 302 other than a boss 302.
The change in 86 was to efi, and to a roller cam in the mustangs.
The roller setup will go into any 302 block, so there really is no changes for the roller cam.
However,in 82 they went to one piece rear main seal.
Old May 6, 2003 | 11:01 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Just make sure that the cam in your 70 engine has the same firing order as the EFI.
Old May 6, 2003 | 11:17 AM
red_rocket's Avatar
red_rocket
good point, with a 5.0 H.O. efi setup you will need a either put in a 351 cam, or even better, swap in the roller cam setup from the mustang.
Old May 6, 2003 | 11:30 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Yes. The fuelie should be 1-5-4-2-6-3-7-8. I didn't even have to look at the notes on my arm for that one.
Old May 6, 2003 | 12:31 PM
JP3's Avatar
JP3
You should have.
The "normal" 302 is 15426378
HO 302 is the same as the 351 order.
-James
Old May 6, 2003 | 12:48 PM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Yeah... I knew that. No really. I did. Maybe I just forgot. Well ok, I'll admit it... I've been working on my Windsor so much lately it's the only firing order I can see... and I mean I see it everywhere.
Old May 6, 2003 | 01:08 PM
cybercoyote
Thank you all. The information is greatly helpfull.
Silly question though. If the cam has the wrong firing order, wont the crank as well?
Old May 6, 2003 | 02:42 PM
red_rocket's Avatar
red_rocket
Nope, because it just changes the order of when the power stroke is.
My BII has a 86 302, with a 351 cam in it, I all I had to do is change the order of the spark plugs.
Old May 6, 2003 | 03:44 PM
90f150moneypit
Just think of the crank as the dumbest part of the engine.....it just does what it is told.
Old May 7, 2003 | 06:08 AM
baddad457's Avatar
baddad457
You cannot just "swap" a roller cam and lifters into a pre roller block. The lifter bores on the roller block are taller to accomodate the taller lifters. To use a roller cam in a non-roller block you can either use a reduced base circle cam and the factory roller lifter setup or a factory roller cam with special link-bar roller lifters ( I think Crane makes these) You can use the EFI setup with your 73 motor if you get the setup from a non-HO motor such as a Crown-Vic or pickup or T-Bird. The roller cams were first installled in Stangs and Lincolns in 1985
Old May 7, 2003 | 06:35 PM
cybercoyote
Allright. Would I be able to use the mustang setup I have (Upper and lower intake, injectors, rail, harness and sensors) but ecxhange the computer for one from a t-bird or crown vic?
Old May 7, 2003 | 11:31 PM
baddad457's Avatar
baddad457
As far as I know the Stang and the Crown Vic/T-bird setup are the same except for the computer. I had one off of an 88 Crown Vic and it was virtually identical to the Stang upper/lower except for the upper was reversed in relation to the Stangs. So yes, I think all you'll need is to get a Crown Vic/T-Bird computer. Then after you get it running, you'll have to make sure the air/fuel ratio is Ok to prevent a too rich/ lean conditon.
streamin along
22
Feb 20, 2011 04:12 PM
joeblow972
Jun 23, 2004 01:08 PM
akita
Jul 29, 2002 06:54 PM
Big Bronco Boy
1978 - 1996 Big Bronco
Dec 15, 2001 01:02 PM
AlM
Mar 31, 2001 11:34 AM
