Hard warm start
Old May 21, 2012 | 04:52 AM
sKuLz88's Avatar
sKuLz88
Hard warm start
I don't know if there is already a thread on this matter if so could you direct me to it. 86 F150 5.0 V8 2WD, two fuel tanks, auto trans, fuel injected, starts fine when cold but is getting harder and harder to start when hot. This isn't something that happened over night it has been steadily getting worse, it has compression, fuel pump is running, starter is turning it strong and at normal RPM. I've since replaced cap, rotor, plugs and wire with no improvement, new air filter. I've had the truck for 6 months and I don't know what was done prior other then a new battery, I know it was new because I went with him to get it but aside from that nothing. Any information would be appreciated.
Old May 21, 2012 | 09:00 AM
Gary Lewis's Avatar
Gary Lewis
I don't know that much about EFI, but I can think of one thing that might cause a problem - injector leakage. I think the system is supposed to hold pressure when off for a length of time, but don't have any info on that because my manuals don't cover the EFI'd trucks. But, if you have an injector leaking then it could cause flooding that would require cranking to clear out. You might try a fuel injector cleaner in the system to see if it helps. And, there is a way to test the system pressure, which would allow you to watch to see if it drops quickly after turning the key off, which would indicate a leaking injector. But, again, I don't have a manual that covers EFI so can't tell you how.
Having said all that, you should pull the codes to see if the computer is trying to tell you what the problem is. Here's how to do that: Link
Old May 21, 2012 | 12:51 PM
sKuLz88's Avatar
sKuLz88
Thanks for that, I didnt even know it had an OBD. If there was a leak in the fuel lines or injectors then it should be hard to crank cold too? I'll try to get them code pulled later today.
Old May 25, 2012 | 10:52 AM
JayzDaddy's Avatar
JayzDaddy
Had a 79 Volare that had a prob. similar to this. It was a carb though but there was a ballast resistor in line to the distributor on a wire that was screwed up.
Old May 25, 2012 | 11:02 AM
84-6.9L's Avatar
84-6.9L
Also check the range on the ECT or engine coolant temp sender. It could be like the issue I had in where the ECT was always reading cold, therefore on a hot start it would imediately flood. The sender is just above the thermostat and has 2 wires going to it.
Old May 25, 2012 | 11:11 AM
82f100460's Avatar
82f100460
Just to be clear...in your first post you stated it is actually cranking by the starter good, then later you refer to hard to crank when it's cold??
So I'm assuming this is for sure not a cranking issue but rather it just won's start correct?
If it's steadily getting worse as you say, that would almost lead me to believe it's something mechanical. Not for sure but seems like it. Something electrical would "normally" be good or bad...but those can fade as well.
Would definately get your codes pulled. That will tell you if you have something wrong with a sensor, voltage or position of something.
Have you checked fuel/pressure? Might be something getting clogged, maybe a filter or in tank LP Pump?
Old May 25, 2012 | 11:31 AM
Coneynew's Avatar
Coneynew
Just a thought:
I had this same scenario a few years back. Turned out I had a 'bad' Ground cable coming from the battery. It would start fine when cold, but barely start when hot. You could try connecting a jumper cable from the (-) Batt post directly to a chassis ground. If your truck starts good when hot, then check your GRD cable for replacement. They can look good from the outside, yet be damaged inside. Good luck.
Blue Rebel
45
Dec 7, 2025 02:26 PM
ohmar99
13
Sep 18, 2009 08:18 PM
IDIDieselJohn
Jul 6, 2009 10:12 PM
GammaDriver
Aug 25, 2002 12:12 AM
GammaDriver
Mar 16, 2002 11:26 PM
