Found an unknown wire under the dash
Old May 20, 2012 | 10:44 PM
Headviking's Avatar
Headviking
Found this plug/wire under my dash just above the fuse box.
What is it for.
I circled it in yellow.
[IMG][/IMG]
Old May 20, 2012 | 11:18 PM
Snuggyworm's Avatar
Snuggyworm
might be for something else. former aftermarket stuff?
Old May 20, 2012 | 11:42 PM
Headviking's Avatar
Headviking
My truck from new. No after market. Only after market in the truck are alarm/remote start.
Old May 21, 2012 | 12:10 AM
Snuggyworm's Avatar
Snuggyworm
tats interesting. i'll have to check my truck to see if it's the same way. i'll keep u posted.
Old May 21, 2012 | 01:18 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
thats looks like the plug that right beside your headlight switch. should be a oval plug where your moveable pedal switch would go. unless your truck has moveable pedals then it goes to nothin.
Old May 21, 2012 | 01:31 AM
Snuggyworm's Avatar
Snuggyworm
Tats nice to know. I got moveable pedals on my king ranch.
Old May 21, 2012 | 06:32 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
Anybody have these wires behind the main fuse block, white, red, small green & yellow with orange stripe?
Old May 21, 2012 | 06:47 AM
kingair41's Avatar
kingair41
Upfitter switches maybe.
Old May 21, 2012 | 12:19 PM
phantomphixer's Avatar
phantomphixer
Those look like the pass thru wires so you can add stuff to your truck. Look under the hood above the brake master cyl and see if they match. Should be 4 stowed there as well.
Old May 21, 2012 | 12:56 PM
m-chan68's Avatar
m-chan68
The adjustable pedal switch has seven wires that are coloured as follows: three black wires (which are ground), one light blue with orange, one light blue with red, one light blue with black and one red with light blue striped wire. If those are the colours of wires you see, then we've identified that connector.
Old May 21, 2012 | 01:17 PM
m-chan68's Avatar
m-chan68
John, I just went out to my truck to have a look to see if I could find that connector. It appears that IS the connector for the adjustable pedal switch. The wires to that connector should be wrapped in red electrical tape, which brings up another interesting question. Is your truck even equipped with power adjustable pedals? I know that your truck is a Lariat, that is equipped with power heated seats. But it seems redundant to have adjustable pedals too, if it has power seats. If the answer is NO, to adjustable pedals, I guess we now know that even on trucks not equipped, the wiring to it is still present. Another piece of useless information I guess.
Old May 21, 2012 | 01:47 PM
r2millers's Avatar
r2millers
Those are the the wires used for your 4 accessory switches on your dash.
You have to get into the under dash fuse block and power up first before using.
I used aux #1 switch for additional front beams.
Old May 21, 2012 | 03:22 PM
Headviking's Avatar
Headviking
No ajustable pedals. So that probably it.
Old May 30, 2012 | 11:37 PM
jtiles's Avatar
jtiles
how do I wire my up fitter switches
i just wired up my up fitter switches in my dashboard and now I have (1) yellow wire for aux 1 (1) green and brown wire for aux 2 (1) violet and green wire for Aux 3 and (1) brown wire for aux 4 I want to wire front strobe to one switch, rear strobes to another switch and halogen lights to another switch don't i need two wires per switch where do i get the second wire from ????I am confused can somebody hook me up with a sketch or explain it to me
Old May 31, 2012 | 12:31 AM
f250rangerexplorer's Avatar
f250rangerexplorer
The up fitter switches only provide power. The ground wire is grounded to the body or frame. Unless you need two power wires the use a butt connector.
Did I answer your question? Or did I miss understand?
