Screeching sound from engine area!
Old 06-08-2012, 04:32 PM
drizzie27's Avatar
drizzie27
drizzie27 is offline
Ok so I have a wierd screeching sound coming frOm under my hood, I did the 3G upgrade and it was making a slight screech then it would go away. Now it's loud as hell and won't go away and get louder when I get on the gas. However it goes completely aaway when I take the negative cable off the battery!?!?!? HELP!!!!
Old 06-08-2012, 04:33 PM
The1nOnlyFordBoy's Avatar
The1nOnlyFordBoy
The1nOnlyFordBoy is offline
Road noise?
Old 06-08-2012, 04:50 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
1) Don't remove battery cable with engine running. Can cause voltage spikes damaging electronics.
2) I suspect belt is slipping, wrong belt, too loose or wore out.
Old 06-08-2012, 04:53 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
its a belt. if anything else was making that sound,, well, it wouldnt be making ANY sound by now.
Old 06-08-2012, 05:11 PM
drizzie27's Avatar
drizzie27
Taking the negative is a way to check the alt is good too is it not? No it's not road noise. This is at idle in my driveway
Old 06-08-2012, 05:13 PM
The1nOnlyFordBoy
Belt problem then
Put a wrench on the back of ALT it will magnetize when working
Old 06-08-2012, 05:54 PM
dbdbb's Avatar
dbdbb
dbdbb is offline
I would say you should also load test your battery, sounds like it is drawing a lot of load from your alt., very possible it is fine but could possibly have an internal problem.
I have a 94 Mustang with a 460 swapped in but I retained the original Alt. and serpentine belt, it also squeals when first started but goes away after a couple of seconds.
Old 06-08-2012, 05:57 PM
351Cleveland C4
with proper tension and a good belt, there should never be squealing......
Old 06-08-2012, 06:02 PM
drizzie27's Avatar
drizzie27
So can anyone determine why when I take off my NEG battery cable it stops squealing? But as soon as it touches the post again it starts again?
Old 06-08-2012, 06:11 PM
351Cleveland C4
the battery loads the alt. making it harder to turn, thus slipping the belt and squeling. i reccomend tightening the belt, or replacing.
Old 06-08-2012, 06:17 PM
drizzie27's Avatar
drizzie27
Thank you, this makes sense
To me now.
Old 06-08-2012, 06:20 PM
351Cleveland C4
you may even need to add a second belt to help... the 3G alts are harder to turn because of the higher amps they put out.
Old 06-08-2012, 08:26 PM
drizzie27's Avatar
drizzie27
I only have a single belt pulley though, you have a part number for a double from autozone or oriellys? What else what I need to change besides that? Freaking casing is so big it wedges between the motor and the bar that goes to the top bolt. Really tight fit
Old 06-08-2012, 10:22 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Defective alternator bearings can cause screeches, so can the bearings found in idler pulleys used with P/S and/or A/C.
Old 06-09-2012, 07:21 AM
drizzie27's Avatar
drizzie27
I do not have p/s ir AC
Quick Reply: Screeching sound from engine area!
