Bucket Seats
Old Oct 3, 2002 | 08:19 AM
FordPerf300's Avatar
FordPerf300
Bucket Seats
I picked up a pair of bucket seats from an 80's bronco and i was wondering if they fit into a 93 F150, i don't see why not. Any input would be appreciated.
Old Oct 3, 2002 | 08:28 PM
msautry's Avatar
msautry
Bucket Seats
Should be a bolt-in unless they're the pedestal/Captains chair-type seats. I believe the floor pans are pretty much the same. Not sure, but you may have to drill a couple of holes in your floor pan for the inside mounting bolts on each seat assembly. Take a look in my gallery and you'll see what the Explorer seats look like in the Bronco.
msautry
Old Oct 4, 2002 | 03:47 PM
sternal2000's Avatar
sternal2000
Bucket Seats
Bucket seats from a Ford Bronco? ugh why even bother, just throw them away like they were ment to be. If you wanted bucket seats you should have gotten them from a Chevy or Dodge, or better yet just buy a Chevy or Dodge. Can't go wrong there, Fords suck anyway
Old Oct 4, 2002 | 03:59 PM
SPROCKET's Avatar
SPROCKET
Bucket Seats
Why did you even bother posting sternal2000 if you aren't even helping? Anyway, enough with the retard....
The seats should be a direct swap but just do what he said above...might have to drill but no biggy.
Old Oct 4, 2002 | 04:08 PM
sternal2000
Bucket Seats
Appartently you have never even done this before so before you start calling people names, I'd make sure you knew what you were talking about about. The mounting holes on the floor are the same, but you will have to drill for the inner one, the ones near the center console. You would also have to get new seat mounts for the passanger side if you wanted it to side back and forth since the one from the bronco only lets it tilt. If you have anymore questions just let me know, instead of going to this "know-it-all crazed Ford guys". And i still think Fords are POS ;-)
Old Oct 4, 2002 | 04:51 PM
SPROCKET's Avatar
SPROCKET
Bucket Seats
That's funny, because my seat's which were directly swapped from a 95 Bronco were a direct swap. In his case if he's going from a bench seat to the bronco buckets then there should be some drilling and braket relocation involved. I just went from 40/20/40 seats to removing the center seat/console to Bronco buckets w/armrest.
Old Oct 5, 2002 | 07:42 PM
sternal2000
Bucket Seats
Yea, he has a bench seat in there now, that's why I said he had to drill for the 4 new holes he needs. Oh, did I forget to mention that I gave him those seats and he's my best friend, I guess I should have said that....
Old Oct 6, 2002 | 09:37 PM
RA101524's Avatar
RA101524
Bucket Seats
I was looking through a Chiltons about the 90 F-150 thinking about doing pretty much the same thing. The bench seats use less attachment points than the buckets. I don't think there are the extra mounting points for buckets.
If you decide to install your own and drill some holes, make sure you think about how you're doing it. A close encounter at speed with another vehicle could make poorly mounted seats into a airplane with really bad landing gear.
Old Oct 6, 2002 | 10:20 PM
brt's Avatar
brt
Bucket Seats
Old Dec 19, 2008 | 11:40 AM
Bigredfan's Avatar
Bigredfan
does anyone know what type of Bucket seats would fit in to my 79 f100 reg cab?
Old Dec 19, 2008 | 11:13 PM
customfoam's Avatar
customfoam
just tap some new holes I did, from bronco buckets 95 to 93 f150 supercab
Old Dec 20, 2008 | 05:34 AM
Bigredfan's Avatar
Bigredfan
thanks ill do that seems like that would make it easier
Old Dec 22, 2008 | 12:23 AM
customfoam's Avatar
customfoam
Yah, just remove the cat shield so you can tap holes on the passenger side.
swickg331
Jul 29, 2008 01:13 AM
mdjohnson
17
Jan 23, 2006 05:58 AM
JoeKnows89
May 21, 2005 01:11 AM
cigarxtc
Feb 11, 2002 09:23 PM
Ford79
Apr 7, 2000 10:00 AM
