Bad AC Condenser Line
Old May 19, 2012 | 01:21 PM
tshrager's Avatar
tshrager
Trouble shooting the AC system today and put some R134 in only to find a leak in the high side hard line. Anyone have an AC diagram or part numbers for these lines? Its the one that comes out of the compressor and heads to the condenser.
Old May 19, 2012 | 01:47 PM
fordpride's Avatar
fordpride
That's the same one I had leaking
This is the one I used
Murray 55315 - Discharge & Suction Line Hose Assembly | O'Reilly Auto Parts
Old May 19, 2012 | 02:12 PM
pjwoolw's Avatar
pjwoolw
Mine has a leak in that area too. Numbers 2,3 and 4 comprise the part number below. Its one piece.
AC manifold and tube Ford part number F5TZ-19D850-A.
Motorcraft part number YF-2158
Old May 19, 2012 | 02:32 PM
tshrager's Avatar
tshrager
Thanks guys. It's actually the line from 6 to the condenser. Is that just part of the whole condenser then? It's right behind the radiator.
Old May 19, 2012 | 02:44 PM
pjwoolw's Avatar
pjwoolw
I've never had a leak in that area. I'm not sure if a AC shop could repair it. Couldn't hurt to ask. E7TZ19712A seems to be the OEM part number. Double check that. $300.00 from Silver State.
Old May 19, 2012 | 02:50 PM
tshrager's Avatar
tshrager
Thanks Pete. It's just past the 90* turn, right where it starts to go in front of the rad behind a retaining ring/screw on the drivers side. My guess is it got corroded there and rub against that ring for years and there is a small whole in the line. Just found condensers from rockauto for $78, never heard of the mfg though. I'm wondering if I could splice in a new section of hard line there with some flare fittings, like a brake line fix.
Old May 19, 2012 | 03:00 PM
fordpride's Avatar
fordpride
Yep that's the condenser
Old May 19, 2012 | 03:03 PM
tshrager's Avatar
tshrager
Thanks mike. What do you think about splicing in a new section of flared hard line with a compression fitting?
Old May 19, 2012 | 03:06 PM
fordpride's Avatar
fordpride
List: Condenser - 1996 Ford F-250 | O'Reilly Auto Parts
Old May 19, 2012 | 03:08 PM
fordpride's Avatar
fordpride
I'd try it. The only thing you got to lose is a littler freon
By the way napa has dupont freon for 9 bucks a can
Old May 19, 2012 | 03:44 PM
tshrager's Avatar
tshrager
That's what I'm thinking. Worse case scenario I have to buy a new condenser which I already need
Old May 19, 2012 | 07:57 PM
fordpride's Avatar
fordpride
If you know someone that works on home A/C they may beable to fix it or a radiator shop
Old May 20, 2012 | 02:59 PM
tshrager's Avatar
tshrager
I decided to cut the bad section out and see if I could fix this without buying a new condenser and this is what I came up with. Went to napa and got an AC compression fitting, part # 201092, to splice the line back together. I messed up and cut out a bit too much so I had to bend the line a bit, but if you're careful, there is room for movement. The new condenser was listed at $130 at napa and this fitting was $24 so I'm very pleased with the fix. Blows ice cold now.
Old May 20, 2012 | 04:27 PM
fordpride's Avatar
fordpride
It's nice to have A/C huh?
Old May 20, 2012 | 04:52 PM
tshrager's Avatar
tshrager
Yes it is. I really wanted it fixed for next weekend. Taking a travel trailer down to Ky for memorial weekend and I didn't want a case of the Glenns with her complaining about the noise/heat.
