Cab interchange question
on the cab you have to watch the rear body mounts, there are two diffrent widths. but its a easy fix. either drill two holes in the cross member to match the cab or drill the holes out in the cab. both possitions are there if you look closely and measure it out.
if you run across a f350 or a f250 cab from 67 to 77 they will bolt right on without any trouble atall.
and another thing...the 67-72 cabs are about 2 or 3 inches shorter so you will wind up with a little bit larger gap between the bed and cab.
any more specific questions send me a email.
