Trail Grapplers for Dummies
Old May 18, 2012 | 03:26 PM
Fontana's Avatar
Fontana
So I've been reading many posts from people who want, at a minimum, a quality all terrain tire. I have decided that when the time comes I want Nitto Trail Grapplers. The problem is they don't come in stock 20" 275 65 20. I'm not interested in modifying the suspension or spending lots of cash. My question is what wheel size is best for our trucks with the Trail Grapplers?
What I want is an American made black deep well wheel that will compliment my forest green paint.
Thank You
Old May 18, 2012 | 05:10 PM
Painted Horse's Avatar
Painted Horse
It does come in the 295/65R20 which is just 1" taller and still uses the stock wheel width. While I have not tried that size, I've heard that you can use that without a lift.
Old May 18, 2012 | 05:32 PM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
295 60 20 is the closest match and will impact your speedo the least.
Tuxedo Scorpion
i too, want the trails - bad. and im goin with the 295 65 20 when i get my 4inch lift installed.
Old May 18, 2012 | 08:05 PM
CornTruckDriver's Avatar
CornTruckDriver
Thank You
not making them in the Super Duty stock tire size is really kind of ahhhhhhh..................DUMB
Old May 20, 2012 | 06:07 PM
cabindoc's Avatar
cabindoc
295 60 20 I have a 2 1/2" level kit, but don't need one from what I'm told.
Old May 20, 2012 | 07:13 PM
Tuxedo Scorpion
hey scott, you think the 295 65 20's will look ok on my truck with the 4 inch lift?
Old May 20, 2012 | 07:26 PM
Andrew010's Avatar
Andrew010
A lot depends on what wheel your going to use Tux.
Old May 20, 2012 | 07:28 PM
Tuxedo Scorpion
ok, so lets throw out a few thoughts. a) stock b) edit: mht fuel - boost 20x9 black / machined
Old May 20, 2012 | 07:31 PM
Andrew010's Avatar
Andrew010
20x9 with a 295 will be ok. 20x10 needs a wider tire, IMO.
Old May 20, 2012 | 07:32 PM
Tuxedo Scorpion
any idea what the stock rim is? im guessing 20x8, but not sure
Old May 20, 2012 | 07:48 PM
Andrew010's Avatar
Andrew010
I believe it is 20x8.
Old May 20, 2012 | 08:05 PM
Tuxedo Scorpion
20 with the 20x9 and the 295 65 20, and a 4 inch gain in altitude, it should look pretty good. im hoping
Old May 20, 2012 | 08:06 PM
Andrew010's Avatar
Andrew010
With the right offset it should.
Old May 20, 2012 | 08:11 PM
Tuxedo Scorpion
i dont want it to stick out too far. maybe an inch or so. what do you recommend based on your experience. yours looks just about right.
