Frame difference between 2wd and 4x4?
Old May 18, 2012 | 12:41 PM
dougbrown's Avatar
dougbrown
Hello, I was looking to find out if the frame has a difference on 2wd and 4x4 2000 f250? I want to swap my dads truck to 4x4 and a friend has a late 99 parts truck. Could this be possible?
Thanks Doug.
Old May 18, 2012 | 12:52 PM
snakedoc's Avatar
snakedoc
there the same frame.
and it has been done before.
Old May 18, 2012 | 01:13 PM
dougbrown's Avatar
dougbrown
Could this be done with an axle out a 6.0 with coil springs for a better ride? Also can someone give me a rough list of things need. Thanks guys.
Old May 18, 2012 | 01:42 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Auto or manual trans?
EDIT: I just saw in your sig its an auto. You will need the transmission and transfer case out of the parts truck. You will need both drive shafts from the parts truck. Will need all the wireing from the parts truck. This is just some of what you will need.
Old May 18, 2012 | 01:52 PM
dougbrown's Avatar
dougbrown
Auto, and the parts truck a 7.3 auto.
Old May 18, 2012 | 01:57 PM
snakedoc's Avatar
snakedoc
is it a manual t-case. if so there is a lot less wire than on the auto hubs.
Old May 18, 2012 | 02:06 PM
dougbrown's Avatar
dougbrown
Truck has manual hubs and manaul t case.
What is the wiring for?
Old May 18, 2012 | 02:26 PM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
Hey dougbrown, where in crapy s. jersey? I'm near hammonton.
Old May 18, 2012 | 03:01 PM
dougbrown's Avatar
dougbrown
I'm from the Camden county area and my dad from Lebanon pa.
Old May 18, 2012 | 03:02 PM
miller_feed
For the transmission.
Manual hubs and t case has no wires or vacuum lines.
Old May 18, 2012 | 03:28 PM
dougbrown's Avatar
dougbrown
So would it be the hole wiring harnes of the truck or just a transmion harness? Sorry for all the questions but trying to figure what best to do. Sell it and look for a 4x4 or do the swap.
Old May 18, 2012 | 04:21 PM
miller_feed
Do you know if the trans in the parts truck is good?
Old May 18, 2012 | 09:18 PM
dougbrown's Avatar
dougbrown
Yes but bad troqurce converter.
Old May 19, 2012 | 12:59 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
As for the 06 axle yes you can do it but you need to do the rear axle too.
Old May 19, 2012 | 06:59 AM
dougbrown's Avatar
dougbrown
So I think have everything figured out but the wire harness. What made 2wd and 4x4 different?
