I just bought a '91 F150 just wanted to know if these are factory rims? thanks
It apperas aftermarket as it looks as if it has way too much offset to the outside to properly center the tire / rim over the bearings as Ford engineered it for maximum bearing life and maximum load capacity.
The way it looks like to me, at least from the pictures standpoint is that the improper offset is going to transfer way too much load to the outer and smaller wheel bearing. That makes it unsafe if it is in truth that way and not just a optical illusion from the way the picture was taken.
