trans flush
Old May 17, 2012 | 05:38 PM
Ian123's Avatar
Ian123
trans flush
What is the average cost of a transmission flush at the dealership? Also, where is this external filter everyone talks about. I stared at the bottom of my transmission for over an hour during my exhaust install and didn't see a filter anywhere. Thanks in advance.
Old May 17, 2012 | 06:00 PM
69cj's Avatar
69cj
I am going to say the average is around 160. The filter is behind the front bumper just left of center if looking at it from the front. Passenger side. Silver looking cannister with built in hex on the bottom.
Old May 17, 2012 | 06:06 PM
Ian123's Avatar
Ian123
Well that would explain why I couldn't find it
Is there any reason I should let the dealer change the filter? Do I need a special tool, will I lose a lot of fluid when I remove the old one, etc.
Old May 17, 2012 | 06:13 PM
69cj's Avatar
69cj
You lose app. 8 oz. changing the filter. Much cheaper to buy it online and change it yourself. Dieselfiltersonline.com. Manf. is NTZ.
Old May 17, 2012 | 08:44 PM
nico963's Avatar
nico963
I payed $300 for my flush.I called six dealers and this one was the only one that did the "Hot Flush".I bought a new filter online and just asked the tech to change it for me.
Old May 18, 2012 | 01:05 PM
Ian123's Avatar
Ian123
edit: remove post
Old May 18, 2012 | 01:17 PM
spytr's Avatar
spytr
Yea, $300 for my flush with Mercon SP at dealer, but pricing may vary for different kinds of fluid.
Old May 18, 2012 | 02:14 PM
ljutic ss's Avatar
ljutic ss
I had a hot flush done at my Ford dealer on May 02 the price was $179.95 minus the filter.
Old May 18, 2012 | 02:24 PM
phantomphixer's Avatar
phantomphixer
$237 out the door May 11, 2012. I supplied the extrnal filter. Changed the internal one the next day.
Old May 18, 2012 | 04:13 PM
Ian123's Avatar
Ian123
The price seems to vary quite a bit. I couldn't see paying more than $200, but if that's what my dealer says I guess I have no choice
Old May 18, 2012 | 05:38 PM
steelhead2's Avatar
steelhead2
Wait a minute......you changed the internal filter after hot flushed and re-filled? Just curious.......
Old May 18, 2012 | 06:42 PM
69cj's Avatar
69cj
Internal filter does not need replacing unless rebuilding the tranny. To do so is throwing money away.
Old May 19, 2012 | 11:21 PM
phantomphixer
Stealhead 2,
Yeah, I just drained the new fluid into a real clean bucket. Dropped the pan and then refilled with same fluid. Internal filter had flecks and specks. Took appx an hour. I will probably do the same again at 100K miles . At 67K now. Peace of mind. Be advised to double check that the seal on the old filter comes out too. Internal cheaper than external one. Go figure.
Old May 20, 2012 | 08:31 AM
kjackson's Avatar
kjackson
Just had ahot flush at Ford dealer @205 but dealer could not get external filter off so I ended up changing it myself cost $18 from dieselfilters online.
Old May 20, 2012 | 07:42 PM
steelhead2's Avatar
steelhead2
Stealhead 2,
Gotchya. I did my internal to. Cheap,and it does give some peace of mind.
