I have a 97 f-250 yester day it died I tryed the cps. Injector oil. Fuses.I changed the fule filter bout two weeks a go. I will say this some times wen I'm setting at the light it'll jest die. I don't know I would appreciate any suggestions
Sure sounds like a cam position sensor issue?? Mine was just doing the same thing.. Maybe if you replaced the sensor already... the plug is damaged or full of oil?
Yes sir the wts light comes on the tac hits 200 I took and clened the filter in side the little hole that's inside the fuel filter sorry don't know what its called. I got the first one from auto zone but I broke it lol so.I went and got one from advanced auto because no one at ford would pick up the phone I have a volt meter and it reads I cheaked all of the connections they read. My dad has one of thoughs obd2 scanner nothing came up I'm allmost at my wits in tomorrow after work I'm going to pick one up from ford I hope it works
If you are getting RPM while cranking I think your CPS is ok... but I am far from an expert...
What fuel pressure are you getting at the canister while cranking...?
Richard
A CPS can be bad and still read rpm's I have o e in my tool box that does it. But here's the odd thing with it in the tac shows 200 rpm but the scangauge shows 125
