I removed my dfr and bench tested it. When I apply pressure to one of the supply lines I get a little pressure out of the other line. Which is why I believe the rear tank is filling up the front. I was wondering if I could put a check valve in the lines before the reservoir to fix the problem.
86 F150 302. I posted here because there are more people here with the efi 302's
