Power Locks
Old May 4, 2003 | 02:41 PM
chadburns2's Avatar
chadburns2
Power Locks
Hi all, I have a '68 F-250 that I want to put power locks in. I have scavenged a couple of two-wire solenoids and a couple of 5-wire switches from a Taurus out of the junkyard. I have got the mounting figured out, but I need a little help with the wiring. O.K. a lot of help. Can anyone steer me in the right direction for a good wiring diagram for this install? Are solenoids really necessary? What else might I need? Any info you all can give is appreciated! Thanks again.
Chad Burns
1968 F-250 390 2v auto
Aurora, CO.
Old May 4, 2003 | 06:27 PM
steve83's Avatar
steve83
Power Locks
Technically, those are lock 'motors' - not solenoids.
You should use the wiring diagram from the same vehicle that you got the switches from - different Ford vehicles use different lock wiring, so you have to be consistent. A Haynes manual will have a good complete diagram, but you might find enough info here or here.
Old May 5, 2003 | 11:56 AM
charlez's Avatar
charlez
Power Locks
What year taurus?
Old Mar 25, 2006 | 01:54 PM
heathric's Avatar
heathric
Talking
Technically a "Solenoid" is a motor.
a motor is "typically" radial motion.
a solenoid is "typically" axial motion
Being an electrical and test engineer for government aviation, I would probably call it a solenoid... or an actuator, which could be either a motor or solenoid.
later,
Heath
Old Mar 25, 2006 | 05:47 PM
Franklin2's Avatar
Franklin2
Here is a diagram for a 91 ranger powerlocks.
http://www.autozone.com/images/cds/g...3d800ba9cd.gif
Look in the middle right of the diagram. See if the colors are the same. If they are, you can follow this diagram and they should work ok.
Old Mar 25, 2006 | 09:56 PM
heathric's Avatar
heathric
Awesome. Most of the wires are the same color. This should help. thanks a bunch
