1969 f100 restoration / cv swap
Yes. It is threaded into the sleeve. When you pull the nuts you must then unscrew the bolts. If you install it in this manner you will be able to pull the upper shock tower supports without losing the entire suspension. I used the factory sleeves in my installation. They are only welded into the CV on the top rail.
Mine was great fun. I did my install in the plant where I worked. Had to have it out by Monday morning. Getting the I Beam suspension out kicked my butt. I hurt everywhere! Then came laying on my back drilling the 4 holes from underneath. The 4 on top weren't that big of a deal. Once my body was sore progress went slow. I ended up pulling it outside with the forklift. No steering, brakes or motor mounts. I got tired and thinking got blurred when it came time to put the crossmember in. Pallet jack wouldn't go high enough to get it up into place. Took me about 3 hrs to figure out "put a block of wood on top of the jack brain surgeon". I had the engine and front clip on my truck. Pulling the engine would have made it go much faster. More room to work.
Worth every bit of effort though.
Please help us understand something critical...
Mr. Kamikazi - About the 2003-up rear end width - since you have one, could you please measure the CV rear, outside to outside of original tires? I could have a CV delivered to my door simply by dialing 9-1-1 but I'm asking you first.
TIA, Eric
TIA, Eric
#28
The axle width on my 2008, from the outside of the tires is about 76.5 inches give or take a half inch
Sounds like I've gotten myself into a bigger project than expected, but oh well. I know for sure that it'll be worth it in the end.
From other peoples experiences, does the aluminum front end weigh less than the steel front end off the trucks?
#29
wiring
When it comes to wiring check out Modular V8 and V10 Conversions and Swaps
lots of good info there answered a bunch of my questions.
#30
If you're going with a CV and an 8.8, strongly consider swapping in an independent rear suspension: Team321 LLC Ford Truck Independent Rear Suspension (321)960-5945 dheld@cfl.rr.com
There is a fellow FTE'er in here whose 97 T-bird was crushed by an oak tree...96K miles. Maybe ya'll can make make a deal.
Here's the page: https://www.ford-trucks.com/forums/1...l#post11832926
Well, that one way to get 5X4.5" lug bolt circle on the back. Not to mention disk brakes, 8.8 rear end, air suspension (with the Mark 8), AND IRS.
