New fan?
Old May 14, 2012 | 10:13 PM
lodogg89's Avatar
lodogg89
New fan?
My shroud is all cracked up and needs to be replace so I figured I'd upgrade a couple other things as well. Truck is a 78 250 custom 351, I'd like to order from bronco graveyard, but am open to other places. I looked into electric fans a little bit but they dont seem to move the air as well, thoughts, opinions? So e-fan or upgrade and if so what blade do u suggest
Old May 14, 2012 | 10:35 PM
ChiefM's Avatar
ChiefM
If you are not going wild on the engine side of upgrades, I would go with a stock replacement shroud.
Old May 14, 2012 | 10:38 PM
Blue and White's Avatar
Blue and White
I just upgraded on a '78/400M. The original fan was fixed and ran full speed all the time. Noisy and couldn't help fuel consumption.
I used a 6 blade fan from AZ made for a clutch, a Hayden thermal fan clutch from NAPA and a 1" spacer to position the fan half way in the shroud opening. 5/16" studs from Ace hardware hold it all together. It bolted up fine and cools well. It has quieted down a bunch.
AZ was the only source I found for the re-pop fan. I used a Hayden clutch from NAPA after a bad experience with the "torqflow" brand AZ sells.
There is a deeper pitch fan also. I don't know anybody that re-pops it so a JY would be the source. It takes a higher capacity/higher torque fan clutch also available from Hayden/NAPA.
Old May 15, 2012 | 09:17 AM
koolchange's Avatar
koolchange
I am going with the Flex Fan from Summit. I will have to let you know how it works out
Old May 15, 2012 | 03:22 PM
PEARLOFTHEDESERT's Avatar
PEARLOFTHEDESERT
just put a flex fan in my truck. sounds quiet and smooth
Old May 15, 2012 | 03:24 PM
PEARLOFTHEDESERT
..should also add that i can really feel the air flowing through when i put my hand in front of the radiator.
Old May 16, 2012 | 07:38 AM
koolchange's Avatar
koolchange
That is really good to hear. This will be on a fresh rebuild. I just want things to stay .
79FordBlake
Aug 6, 2012 09:33 PM
79FordBlake
Jun 25, 2011 11:49 PM
CANYON
1978 - 1996 Big Bronco
May 3, 2004 09:24 AM
agelder
Aerostar
Aug 7, 2003 01:00 PM
bigric
Mar 7, 2003 08:23 PM
