Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
O2 Sensor Location
Old May 14, 2012 | 11:31 AM
tico2k2's Avatar
tico2k2
O2 Sensor Location
Hey All,
I am new to this forum and need some help. My 2001 3.0L V6 Escape check engine light went on, we had it checked and it came back that I need to replace the bank 1 downstream O2 sensor. I found both of the sensors under the engine, but I don't know which of the two that I saw was the correct one. Can someone please help me out?
Thanks
Mike
Old May 14, 2012 | 11:50 AM
tomw's Avatar
tomw
Bank 1 downstream would be the sensor after the converter on the bank closest to the firewall. Upstream would be ahead of the converter. Bank 2 is the front bank of 3 cylinders, #'s 4,5,6. I think there would be another sensor near the final converter in the exhaust pipe.
tom
Old May 14, 2012 | 08:03 PM
projectSHO89's Avatar
projectSHO89
Fault codes NEVER tell you to replace a part. They are only a data element that must be used as part of a diagnostic procedure.
Your vehicle has four O2 sensors....
Old May 15, 2012 | 07:01 AM
wptski's Avatar
wptski
In most cases an O2 sensor is just the messenger of how things are running unless the code is for the heater within the sensor itself, in which case it can be the O2 sensor itself or the circuit that feeds it.
ungerp
1983 - 2012 Ranger & B-Series
Nov 7, 2012 08:39 AM
f142f142
1997 - 2003 F150
Jun 22, 2011 09:05 PM
V10_Cougar
Modular V10 (6.8l)
31
Sep 26, 2007 12:12 PM
CobraXP
22
Aug 31, 2006 10:59 AM
jasmo
1997 - 2003 F150
Jun 5, 2004 01:36 PM
