Need some help with a solid axle conversions
Old May 13, 2012 | 11:01 PM
grizzly11's Avatar
grizzly11
i have a chance to buy a late 99 superduty with a 6spd that has passenger side damage and a burn wire harness for $800 i have a 96 F-250 7.3 5spd that i bought recently that has the solid axle under it, but i would like to have disk brakes in the rear, but the axle is a d50 from the 99 correct? What is involved, cutting the leaf platforms off and moving them? And what is the difference between a d50 and d60?
thanks
jared
Old May 13, 2012 | 11:13 PM
ReBilld's Avatar
ReBilld
thanks
jared
Are you wanting to put the rear axle from the '99 in the '96?
You said the '96 has a solid axle under it. Has the front been swapped to a solid axle or are you talking about the rear?
Old May 13, 2012 | 11:37 PM
madpogue's Avatar
madpogue
You would need to swap both axles in any event. The lug spacing pattern is different (6.5" on the OBS, 170mm on the SD).
Old May 14, 2012 | 06:13 AM
grizzly11's Avatar
grizzly11
The front has been switched to a solid axle with tapered roller wheel bearings and the track bar bracket on the passenger rear side of the axle I would like to have disk brakes but I also would want my bolt pattern to match on all 4 rims. Its probably not worth the hassle is it since its already done.
Old May 14, 2012 | 01:52 PM
BadDogPSD's Avatar
BadDogPSD
Here's a link that may help you:
https://www.ford-trucks.com/forums/1...-on-6-5-a.html
Old May 14, 2012 | 03:38 PM
fordman67's Avatar
fordman67
If u already have a straight front,sounds like a lot of work for nada.but for 800 there are a lot of parts to use or sell.i would buy it for other reasons and sell others.
Old May 15, 2012 | 01:53 PM
grizzly11's Avatar
grizzly11
I now realize that its not worth it but buying the truck for other reasons is more logical
Holdmybeer
Feb 15, 2019 05:33 PM
Dobies4life
Nov 3, 2013 02:15 PM
fbavaro1
Oct 30, 2011 10:27 PM
1969furd
Large Truck
Feb 18, 2010 05:13 PM
