nonsynchronized 3-4 4speed
Old May 13, 2012 | 08:08 AM
BRay09's Avatar
BRay09
Was there ever a such thing as a nonsynchronized 3-4th 4 speed trans that cane behind a 87 f350 460?
Old May 13, 2012 | 08:16 AM
Diesel_Brad's Avatar
Diesel_Brad
Yes and no.
All gears were synchronized except 1st and reverse
Old May 13, 2012 | 09:15 AM
BRay09's Avatar
BRay09
Oh. In this truck you have to let it idle down to shift from 2-3 then 3-4. Think the synchros are bad? It is a PTO trans if that makes any difference
Old May 13, 2012 | 09:54 AM
pfogle's Avatar
pfogle
Check your clutch pedal bracket for cracks. If that checks out you may be in need of a clutch. It sounds like it's not releasing.
Old May 13, 2012 | 11:07 AM
BRay09's Avatar
BRay09
It shifts well and releases ok. Just if you go straight from 2-3 with clutch in, it'll grind. 1-2 is normal, but the 2-3 then 3-4 you gotta let it idle down or it'll grind. Not a big deal, but just want some opinions on it
Old May 13, 2012 | 01:43 PM
fdude64's Avatar
fdude64
make sure the pto is disengaged maybe the cable has slipped and it isnt going all the way out of gear
Old May 13, 2012 | 02:01 PM
BRay09's Avatar
BRay09
The PTO is not on it at the moment
Old May 13, 2012 | 06:49 PM
Diesel_Brad
You need syncros
All the 4 speeds had PTO openings
The NP435 has an aluminum top cover and passenger side PTO
The T18 has cast top cover and passenger side PTO
The T19 has cast top cover and PTo covers on BOTH sides(you "should" have this one, being it is behind a 460)
All of which have syncros
Old May 13, 2012 | 09:19 PM
BRay09's Avatar
BRay09
Yeah I have the t19. Is it a necessity to have those though? Using it for what I need it for, it will do just fine as it is, but I don't want something else blowing up while using it because those are bad
Old May 14, 2012 | 04:19 AM
Diesel_Brad
No. You dont "need" them. As long as you CAN shift with OUT the clutch you will be fine, OR wait for the trans to slow down and ease it into gear between the shift
1972fordhighboy2
Dec 17, 2024 02:19 AM
nicksorenson
Jul 9, 2017 07:40 PM
B.Les
Aug 2, 2015 10:09 AM
JoeyB94
13
Jan 24, 2010 01:32 PM
heavytruck
Feb 20, 2003 12:33 PM
