DEF consumption weirdness
Old May 12, 2012 | 10:09 AM
Biggziff's Avatar
Biggziff
At 6700 miles my truck indicated that the DEF tank had about 600 miles left so I bought 2.5 gallons and dumped it in (Blue DEF) Last week I drove to MD to get the new fiver and on the way back I got a similar indicator that DEF was low. Truck has about 7100 miles on it. I bought another 1.5 gallon jug and dumped it in.
Seems pretty weird that it would use less than 5 gallons in 6700 miles and then use a few gallons in 400 miles, no?
Anyway...got 12+ MPG towing the new fiver home (Cougar 293SAB) at 65 or so. More power than I can use and comfy.... gotta love these trucks.
Old May 12, 2012 | 11:07 AM
AMEC Electric LLC's Avatar
AMEC Electric LLC
I would fill it up....5 gallons or so...then see where you stand.
Old May 12, 2012 | 11:19 AM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
i thought for sure when i took delivery of my truck i had a full DEF tank. but now i realize there is no way to know as the DEF indication is sort of an idiot light (DEF OK). so when i did my new engine 1000 mile oil change i filled the DEF tank as well. took 2 gals. which tells me it prolly wasnt full to begin with.
Old May 12, 2012 | 11:51 AM
Biggziff's Avatar
Biggziff
Ya but... I went nearly 7k on the initial tank. 50% towing. Weird that 400 miles seemed to burn up 2.5 gallons!
Old May 12, 2012 | 11:52 AM
Tuxedo Scorpion
my 1000 miles was no towing and all stupid city type driving.
Old May 12, 2012 | 02:45 PM
ruschejj's Avatar
ruschejj
DEF usage is directly related to engine load, fuel consumption, and exhaust gas temp. I suppose you could nail it down to one thing, engine load. Ambient air temp has something to do with it too.
So, if you want to use a lot of DEF, pull the most wind resistant trailer you can find at 75MPH. It's all about NOx. Lots of NOx is made when the engine is working hard, so more def is required to reduce/remove NOx.
Old May 12, 2012 | 03:17 PM
Biggziff's Avatar
Biggziff
Yep I understand that. That's why I'm so puzzled that it seemingly used so much in 400 miles. Ah well...
Old May 12, 2012 | 04:48 PM
2ndStroke's Avatar
2ndStroke
Your def tank only has a couple sensors to tell the def level. Fill it right up so it reads full and see how long it takes to burn the tank.
Old May 12, 2012 | 05:13 PM
kper05's Avatar
kper05
600 MTE is low.
My guess is the 2.5 gallons didn't trip the full sensor.
I fill with 2.5 gallons when I see DEF under half message.
I've never had the 800 MTE message appear.
Did you run a system report after it stopped counting down?
I'm curious if it reported under half or DEF OK.
Old May 12, 2012 | 05:22 PM
Biggziff's Avatar
Biggziff
Originally Posted by kper05
600 MTE is low.
Once I dumped in the first 2.5 gallons the system reported DEF level OK.
Who knows....weird to be sure.
Old May 12, 2012 | 09:29 PM
DSLPWRD's Avatar
DSLPWRD
I had the same issue. 5300 miles and I got the 800 MTE message. Drove about another 150 miles and added 2.5 gallons. 300 miles later, 800 MTE again. Drove about another 150 miles and added another 2.5 gallons. I've driven about another 500 miles since then, display still says OK. We'll see how long it lasts. I just wanted to add enough to hold me over to my "paid" oil change and let the dealer fill it up.
Old May 12, 2012 | 09:43 PM
cford716's Avatar
cford716
That 2.5 gal probably barely gave you half and just tripped the sensor at the half mark which gives you the "OK" indication. Basically at 51% full is says "OK". Then burned up a bunch pulling. I am not sure if it is like the DTE where it uses the current rate to predict how many miles are left or is it just a sensor period?
Best thing like others said is fill it up, get 5 gal. in there not just till it says ok and see what happens.
Spoojr
Dec 14, 2017 07:07 PM
GW09F350
6.7L Power Stroke Diesel
27
Aug 27, 2014 08:17 AM
eruji
Nov 20, 2012 09:52 PM
jdadamsjr
15
Apr 27, 2012 09:01 AM
X GM GUY
Sep 12, 2006 03:08 PM
