I'm logged in because of the remember me box is checked. i went to change my email address and I can't remember which password I am set up with. Since I no longer have acess to the older email a new password can not be set up. Help!!!!
Wouldn't you also be able to pull it out of your browser preferences? Have it show you the saved passwords it's using.
If he's just got the "remember me" box checked, the browser stores the authenticated login session in a cookie. Unless he can decrypt that he can't get the password. It's not stored in clear text.
Chris, you're probably thinking of Firefox's password database that you actually can get to show you the saved passwords.
There is at least one utility out there to extract this information and present it to the user, Firefox conveniently has this functionality built-in.
I am a Linux user and and initially had thought that IE had some sort of "show passwords" stuff built into it. If I'd known MS makes it so hard, I never would have thrown that out there.
I used to be a "Admin" on another forum that used "VB" software. I could access a user account and see almost anything the user could see. The password was not visible, but it did have an option to change the password in the event a user needed to have it reset (like this situation).
All that is needed, is a valid email address to send the "new" (temp) password to, so the user can login using it, then change it to whatever they want.
