302/AOD Mounts
Old May 7, 2012 | 09:25 PM
ChuckRob's Avatar
ChuckRob
302/AOD Mounts
I am just about ready to order Engine /Trans mounts for my 48 F1. I like the cross member style mounts because I would think that they stiffin up the frame a bit. It seems like everybody sells them, are they all made by the same manufacture or are some better than others? The transmission cross member are also available with different amount of mount heights. What height will get me close to the right pinion angle? I am using a 9" rear end at stock spring height and an AOD transmission. Can the engine and transmission be centered or do they have to be offset for power steering (Toyota) and Patriot block hugger header clearence?
Thanks for your help.
Outlaw56
Feb 1, 2017 04:29 PM
vanspeed
Nov 2, 2016 06:47 PM
Ron_coach
Mar 23, 2008 12:58 PM
gquinn8516
Jan 1, 2005 09:25 PM
tip49
Dec 22, 2004 07:18 PM
