My 1962 Ford F100 4x4
on
Raining and blowing and just flat smoking. My 12 year old boy is out on a survival camping trip with not much more than a rain coat and a knife. Left Saturday and is do back next Saturday. Unless they call us we have no idea what is going on. One man and two 12 year old boys on a deserted Island in this storm. Just the way they grow up in Alaska.
Now thats survival training, sink or swim.
on
Well this morning is really nice. The storm blew over and the sun is out. Looks to be a really nice day. And I have got to spend the day cleaning the house. My 10 year old and his friends have been hanging here all weekend because the weather was to bad even for them to go out. And every damn room looks like a storm hit it. But it's all good. He watch "A River Runs Through It" three times and now I got to get a bunch of fly fishing poles and gear and teach him how. I haven't Fly Fished since I was 12 years old.
Sorry Bud
Sorry Bud
The lever lock is manual, non electric made by Mico. I guess you press on the brake and move the lever up to lock the brakes up, it moves a piston inside the unit which blocks off the ports. Mine is so old it doesn't have the electrical part on the back. Here is a link to what I'm talking about
http://www.awdirect.com/lever-lock-m...ake-locks-pto/
on
WoW!! I have used a lot of them things back in the day. It's not much more than a line lock. Last one I remember was around $50.00 back in the 80's. They must use gold in them now. But they do the job and do it well. Lock all four tires. Be sure and apply it Before ya put the tranny in park if on a hill.
Well been working on the brakes the last couple of days. I bought a brake cylinder hone and some rebuild kits and went through all of them. Only one was really bad it just need more honing. Several had a lot of crud inside most likely from the combination of steel and aluminum. I had to wait to bleed them because the from wheel cylinders haaad stripped bleed screw hexes. I got them in today and am heading out to pull the old ones and install the new then bleed. I might even reinstall the lever lock to see how it works as well.
#28
Well the burnt wire turned out to be the coil resistor wire. It was still running with out the insulation on it. The outer insulation coil kept it from ground. I ordered a new resistor wire from NAPA and got it back in. She started right up no problems. When I had the instrument cluster out I found the PO had fused the heater off of the voltage gage installed in the cluster. The fuse was blown, most likely from bad wiring. I installed a 15 amp fuse instead of the 25amp that was in it, and my heater motor is working. The oil pressure gage plastic tube broke off so picked up a new ferrel fitting and fixed it as well. I think one day I will devote some time and clean up the whole wiring. Removing cut off wires that go to nothing, shortening long wires. The firewall could use some love as well.
The brake pedal feels higher that it used to be so plus one for me. For those of you with manual transmissions, where does your clutch start engaging when you let out the clutch pedal?
