Testing a coil
Old May 3, 2003 | 03:21 AM
MikeConolly's Avatar
MikeConolly
Testing a coil
Does anyone know how I can test my coil. I have no spark and need to fault find. Battery is OK, Motor swings. Coil measures 9.6 volts when motor is turning.
Thanks
Old May 3, 2003 | 10:05 AM
tellico racing's Avatar
tellico racing
Testing a coil
I will assume you have a 73-79 Model truck. Everytime I have had a no spark problem it turned out to be either the spark module, (silver/gray metal box on drivers side fenderwell) or the wire connections at the coil.
Old May 3, 2003 | 07:46 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Testing a coil
Mike, the primary resistance should be about .8 to 1.6 ohms. Measure this between the two small terminals (+ and -).
The secondary resistance should be about 7.7K to 10.5K ohms. Measure this between the coil negative terminal and the large center terminal (where the cap wire connects).
I agree with Tellico, you probably have a faulty ignition module.
