Pimp my 8200
Pimp my 8200
This is my new (to me) 2005 F150 XLT 8200lbs heavy duty package. It has the Leer cap which I have on most of the time.
My first change will to be to make me a cat back system. I intend to run the pipes back to the drivers side between the chassis rail and the bed side and mount a pair of flowmasters up there and the run the pipes out sideways ahead of the rear tire. This is to free up space where the muffler (huge thing!) was. I want to mount my LPG tank there.
Anyone know which are the best flowmasters to use? I want a deep V8 sound without any cackling or droning at freeway speeds.
Next up come the LPG gas conversion. Expensive but LPG costs less than half what gasoline costs over here.
The wheels are bugging me thou. I have a set of nice brand new chrome 2009 Lariat take offs but they're 6 lug. My stupid 8200 is the only F150 with 7 lug wheels! What's involved in converting my axles to 6 lug? Is it possible and affordable. We have a lot of snow here in the winter so really I need to be able to run two sets of wheels for my summer and winter tires. I have a workshop, so converting back to 7 lug for the winter won't be too much of a problem.
Finally any other thoughts on making it look a bit nicer. I find it looks quite drap. Of course the ugly wheels don't help. Also the tech tubes are letting it down looks wise too. I think it needs more chrome. Any ideas
Ed
If you want to make a move for the looks then get a chrome package for it. Chrome grill and door handles will really make it jump. I would also get some chrome or stainless step bars to dress it up a bit and maybe a 1.5-2" leveling kit.
As for the flowmaster mufflers the 40 series is loud and drones on but I believe you can put a 50 or even 70 series under these trucks to get less drone. I would maybe look into a series 50 it is what they call their mid range sound where the 40 is the aggressive and the 70 is mild.
Ed
Now I know nothing about the laws and regs in Germany, but to me I think the extra hassle and expense would be better than switching from 7 lug back to 6 lug then back to 7 lug each year. If you're mechanically inclined then go for it, but that sounds like a lot of work and time, and also money.
As for the exhaust...Flowmaster is going to drone. Magnaflow, Gibson, MBRP probably won't drone as bad. I had a Flowmaster 50 series on my V8 Explorer and it had a drone sweet spot right at 2k rpms. Really sucked on the highway.
Maybe those 2011 17" OEMs are my best bet.
Thanks for the tip on the Flowmaster. 2000rpms is just where I drive at.
Ed
for what its worth maybe powdercoat the wheels. they are a bit off looking but maybe more chrome on the truck and chrome center caps with black powder coating on the rest. just a thought!
my exhaust sounds great, has a drone but at like 3000-3500 rpms so its nice and loud when your getting on it but on the highway it is very quiet in the cab, its an edelbrock SDT kit. mine is the saleen edition but they should be all the same. got mine on ebay for around $200 with S+H
Lifting is OK, so are many other modifications. With most modifications, the inspection guy just checks it looks safe and puts it the paperwork. Wheels are pretty critical, and to be fair many cheap aftermarket wheels aren't safe. We have unlimited speed limits here so you can drive at V-max for hours if you can find the space to do it.
I like the idea of powder coating the steel wheels as my winter wheels. I'm going to buy some 2011 17" OEM 7 lug wheels for my summer tyres.
I've ordered stainless running board tubes to replace the rusty old tech-tubes.
Somewhere, but I can't remember whether it was here or somewhere else, I read a tech about swapping the XLT grill for some other OEM chrome grill.
LPG doesn't change the sound of the engine. Changing the exhaust, cat back is OK, especially if it's done to free up space for the lpg tank ;-)
The Edelbrock exhaust kit for $200 sounds reasonable. Is that for one or two mufflers.
Ed
Ed
Bamberg, Baveria.
Well here's how my truck looks now one year later. I swapped the rusty old tech-tubes for new stainless tubes. I made up a twin cat back system using flowmasters which sound good and aren't to loud of droney. It's running on LPG now. I bought the chrome stick on grill and door handles which improved the look a lot.
This week I fitted new coils and shocks up front with a 2" leveling kit. Man they were a ******* to get in! I bought a set of Eagle alloys with the 7-lug pattern and Cooper Discoverer 35s. Now I have a set of Bush-whackers on order.
And with it being a HD it already has 4.10 gears!
Before and after
Before and after
