moving to a open diff to LS tough?
Old May 3, 2003 | 01:01 AM
mrak's Avatar
mrak
I have a 1994 with a 5.0, E4OD. Pretty decent truck. My only gripe is that it has poor traction. Right now I have 3.08 gears with an open diff. How tough would it be to make it a limited slip diff and how much money would I be in for if I did it myself, or if I had the shop do it?
I thought about buying a rebuilt 3.08 with LS from jasper, but they were expensive (near $2k!).
Matt
Old May 3, 2003 | 08:41 AM
MustangGT221's Avatar
MustangGT221
Just search ebay for a 31 spline Traction Lok from Ford. I got a used one from an Explorer for $50. Came with the toner ring, the side/spyder gears and clutches. I did put new clutches in it however, $75 from Ford. Swapping carriers is pretty easy, because you don't have to mess with the pinion gear.
Old May 4, 2003 | 12:12 AM
steve83's Avatar
steve83
Changing the diff carrier doesn't affect the pinion preload, but it does affect the gear mesh, and therefore, backlash. They still need to be set up properly, and you should let a pro do it. Cost should be $75-200, and you might as well redo the whole axle while you're at it - bearings, seals, pinion shaft lock bolt.
Old May 4, 2003 | 10:12 AM
MustangGT221
True but the backlash shouldn't move that much, still needs to be checked of coarse. Working on the pinion is most of the trouble when working on an axle, so since you're not messing with that, it'll be a lot easier. Whether or not you should rebuild the whole thing, depends on how old it is, and how many miles are on it. Changing the carrier is cheap/easy. Rebuilding the axle is time consuming and costly because of the pinion and the other bearings/seals.
