Sponsored by: Kumho
abs code c1288 on scanner - need help
Old May 6, 2012 | 10:14 AM
mdec950's Avatar
mdec950
2007 expedition xlt 5.4L
2wd and has tcs and roll stability
getting c1288 code on brake scanner
says its PRESSURE TRANSDUCER MAIN/PRIMARY CIRCUIT FAILURE
how do i get this repaired ?
Old May 6, 2012 | 01:13 PM
Lazy K's Avatar
Lazy K
Faulty ABS pump. Apparently not uncommon. Bad news is Ford charges an arm and a leg for a new pump, good news is that you can get it repaired with modifications to stop it happening again.
bashby
Sep 17, 2012 01:50 PM
