Steering Pull
Old May 5, 2012 | 03:07 PM
JonathanN's Avatar
JonathanN
Gonna put the front on stands, hit the brakes, then see if one wheel is harder to turn than the other after I release them. As for grease, I'm positive they pins are greased because I had put so much in there that I couldn't get the calipers to slide on all the way until I picked some of the grease back out.
Old May 5, 2012 | 03:43 PM
jdw1's Avatar
jdw1
Sounds like your pins have to much grease in there if they are hydrolicing!
Old May 5, 2012 | 04:10 PM
JonathanN's Avatar
JonathanN
They were... had to dig alot of it out. They're good now, but I know I've got enough grease. The dust boots have the greasy film to prove it!
Old May 7, 2012 | 08:34 AM
JonathanN's Avatar
JonathanN
Alright, jacked the truck up, started the motor, and worked the brakes... pumped them, held them, everything I could think of and both wheels had the same resistance after I let off the brakes. The amount of brake sticking to cause the truck to pull when the speedo needle isn't even off 0 would have to be pretty substantial... with the truck rolling in neutral, I don't think even my grabbing the tire could make it pull the much.
Old May 7, 2012 | 09:13 AM
WA.Ranger's Avatar
WA.Ranger
Bleed the brakes. I'm thinking that 1- truck won't mind new fluid, 2- it might give you insight into a pinched line or something.
Old May 7, 2012 | 09:28 AM
JonathanN's Avatar
JonathanN
Well, I would but I did brakes 20k ago and bled them more than necessary just be sure. I also have all-new rubber lines.
Old May 7, 2012 | 09:29 AM
JonathanN's Avatar
JonathanN
But... You never know. Might be worth a shot?
Old May 7, 2012 | 09:41 AM
izzybird's Avatar
izzybird
Ummm.... What tires are you running? MT's right? 30k with 50% left is awfully good, you need to do more burnouts! I've got 15k on my Coopers and though the traction is phenomenal, I don't think they have another 15k in them. I don't know what to say about your pulling, except it's gotta be something!?! Big help huh.
Old May 7, 2012 | 10:05 AM
JonathanN's Avatar
JonathanN
Haha! Yeah, I might oughtta burn more rubber... I actually have BFG All-Terrains. Every set my dad an I have put on have gotten 60K+. Quiet and fantastic road manners... I love them!
Yeah, you're no help...
Old May 7, 2012 | 12:47 PM
jdw1's Avatar
jdw1
We are running out of things to check!
So how about the rear brakes?
Old May 7, 2012 | 01:09 PM
JonathanN's Avatar
JonathanN
I know, right!? Rears are good too... I REALLY don't think it's my brakes.
So here's what I want to know: does the box have a "center"?
Old May 7, 2012 | 07:57 PM
AMG-SM's Avatar
AMG-SM
How do you know that your alignment is good? Do you have the printout with the results?
Same tires all around?
Old May 7, 2012 | 08:04 PM
  #28
JonathanN's Avatar
JonathanN
Same tires, always rotated every 5K with oil changes. Only reason I know the alignment is good is I know the guys doing it, I trust them, and they've shown me what they did every time. They wrote the specs for the alignments on a pad and brought it out to me.
Old May 7, 2012 | 08:54 PM
  #29
jdw1's Avatar
jdw1
How about your 4x4 locking hubs? One locked and one not locked!
Old May 7, 2012 | 08:57 PM
  #30
JonathanN's Avatar
JonathanN
Checked them many times, both are unlocked...
BenFranklin
Nov 4, 2014 07:43 PM
DetailerDave
Nov 9, 2009 08:25 PM
Bullride_101
Oct 29, 2006 05:23 PM
bertcakes
27
May 2, 2004 07:39 PM
