Weak brake pressure
Old May 3, 2012 | 10:13 AM
whiteisright's Avatar
whiteisright
Weak brake pressure
I rebuilt the from drums, and replaced the master cylinder, but i am still having to pump the brakes to come to a stop. I bench bled the master until no air came out of the ports, and I have bled each wheel at least a dozen times. Still not good pressure. Any ideas? I havnt seen any fluid leak out of any drum and I rebuilt the fronts at least 2 months ago.
I have the parts to rebuild the rear, but after gettin my wheels and spacer un bolted last night, I realized the floating axles have to be removed, therefore new seals needed. Either way, I havnt noticed the rear drums leaking anything.
Old May 3, 2012 | 11:15 AM
montana_highboy's Avatar
montana_highboy
Are the rear drums adjusted, the shoes should just barely drag on the drums, if not adjusted properly the shoes can take up a ton of pedal travel before they engage the drums.
Old May 3, 2012 | 11:18 AM
whiteisright
Havnt adjusted, but this could be the cause for having to pump quickly 3 or 4 times before I get hard pressure?
Old May 3, 2012 | 11:24 AM
montana_highboy
You'd still have pressure but it would be at the very bottom of your pedal travel, making it feel like there's no pressure until the shoes engage.
Old May 3, 2012 | 11:43 AM
whiteisright
Ah, the pumping gets it hard pressure at the top of the pedal, and then the difference in muscle I have to give it to brake is incredible haha. Almost like I have power disk brakes after 3 or 4 pumps
Sixtiesmusclecarguy
13
Jun 25, 2017 02:46 PM
rustywheel68
Dec 4, 2015 08:14 AM
Gembone
15
Oct 31, 2015 07:18 PM
redneck1377
Jul 12, 2007 06:52 AM
johnwb
17
Aug 26, 2001 11:45 AM
