Blue spring part #?
Old May 3, 2012 | 08:03 AM
lakewood's Avatar
lakewood
Blue spring part #?
Does the blue spring upgrade come together with everything needed in one package? Or do i need to buy all the parts separate? Its probably been asked before but my search wasnt turning up anything.
Thanks
Old May 3, 2012 | 08:29 AM
jeep.hauler's Avatar
jeep.hauler
Motorcraft 3c3z-9t517-ag everything is in this kit except the housing.
Old May 3, 2012 | 08:33 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Blue Spring
Upgraded fuel pressure regulator kit (with cover): Ford#3C3Z-9T517-AG*IH #1843065C98
Fuel Pressure Regulator "Spring and Reseal Kit Only" (no cover, should be much cheaper, has gasket): Ford#6E7Z-9C165-B IH#1854267C94
Regulator cover gasket only: Ford#3C32-9C065-AA
Old May 3, 2012 | 08:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jeep.hauler
Motorcraft 3C3Z-9T517-AG everything is in this kit except the housing.
3C3Z-9T517-AG ~ MSRP: $80.00 / FTE sponsor tousleyfordparts.com price: $52.80 (Tousley: White Bear Lake MN).
Old May 3, 2012 | 01:30 PM
lakewood's Avatar
lakewood
Originally Posted by Rusty Axlerod
Blue Spring
Do I need the cover? Or does the original cover work?
Old May 3, 2012 | 01:32 PM
lakewood's Avatar
lakewood
If anyone knows the part number for fuel filters from international that would be awesome. Im gonna see if they are cheaper
Old May 3, 2012 | 02:09 PM
Rusty Axlerod
Usually the old cover is fine and can go right back on.
Old May 3, 2012 | 02:46 PM
Dieselpop's Avatar
Dieselpop
Old May 3, 2012 | 04:36 PM
kidoo's Avatar
kidoo
One question about the rail fuel filter on the link Racor PFF4616 Racor Fuel Filter / Water Separator 03-07 6.0L Power Stroke , does it have an O ring on the bottom of the filter, it does not show on the picture.
This one is a motorcraft: Ford 6.0 Liter Turbo Diesel Motorcraft FD-4616 Fuel/Water Seperator Filters(FD4616): Pick Up & Excursion-REPLACES MOTORCRAFT FD-4604-NEW UPDATED - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks ?
I bought a Fleetguard filter and it did not have the same bottom end as the Motorcraft, but I mesured eveything and it fit exactly the same. The Fleeguard just has a coned plastic that fit in the bottom on the rail housing, the motorcraft has a longer plastic end piece with an O ring.
Old May 3, 2012 | 04:47 PM
kidoo's Avatar
kidoo
I just did a little search and this one: Motorcraft FD4616
Replaces this one: 3C3Z9N184CA and others. Now I feel more relaxed because this old one is just like the one I put in mine, I was really not sure to install it because it has no Oring, now I see this was and older model.
You can see a good picture of the old one here, and the guy had a freeking good idea: Fuel Filter change on the 6.0 - Ford Powerstroke Diesel Forum
Maybe this is one reason for a different price on the one without O ring, old stock?
Old May 3, 2012 | 06:02 PM
Dieselpop's Avatar
Dieselpop
Yes they are the same one is the old style but does your Fleeguard filter have the water membrane rapp to keep the water out.
pop
Old May 3, 2012 | 06:48 PM
kidoo's Avatar
kidoo
Yes it did have the membrane, the only diffenrence was the O ring, and the big difference was the price. Here in Quebec, Perron Ford wants $104. for the kit, over a 100 for an Air filter, etc.
Old May 3, 2012 | 07:13 PM
lakewood's Avatar
lakewood
Thank you everyone who provided links
Old May 15, 2012 | 01:33 PM
lakewood's Avatar
lakewood
Im finally about to order the fuel filters but they say a max psi of 58? Doesnt the blue spring make 70 psi?
Old May 15, 2012 | 02:32 PM
Dieselpop's Avatar
Dieselpop
The max pressure is 70-75lbs mine runs 62-64lbs at idle and 58lbs at WOT, you will be fine plus your injectors will like you for it.
pop
