c6 questions
Old May 6, 2012 | 11:29 PM
Stangrcr1's Avatar
Stangrcr1
If it is not pumping, I would lay odds the converter shaft or the pump is damaged. Probably both.
Your father in law is wrong on this one.... And tell him since it is his fault, he gets to pay for the fix.
When you take it back out, pull the pump and check it. I think you will find bad news.
Old May 7, 2012 | 03:00 AM
Ken Blythen's Avatar
Ken Blythen
Originally Posted by 82f100460
There are taps on the side of the tranmission that allow you to put a pressure gage for testing. Not sure if you have any gages that can be installed...but would be a good way to see if you have any pressure at all.
No offense, but I would definitely NOT run the engine again until you have been able to sort the converter engagement - it will just chew up the pump & converter hub more.
Old May 7, 2012 | 07:45 AM
bruno2's Avatar
bruno2
I think Ken said it earlier. You need to feel the converter dropping through the splines. It will make a definate "thunk" sound whenever it engages. If it didnt you are lucky the bellhousing didnt break whenever you tightened it all up.
The good news is that I have a TC and a pump sitting in my garage that you can have if you need it. They worked fine when they were pulled. Pay for the shipping and they are yours. I have had them listed in the free parts section and nobody has claimed them yet. I belive the TC is for a 4x4 truck and has a factory stall set up.
The odds of you burning something up arent very high at this point because you havent driven it. However, like Ken said if it isnt lined up properly something is going to get chewed up if it already hasnt.
Old May 7, 2012 | 11:36 AM
goofy3392's Avatar
goofy3392
Ok thanks for your help guys.
And thank you Bruno I will let you know later if I need it.
Old May 11, 2012 | 04:14 PM
goofy3392's Avatar
goofy3392
Found the problem today, the inner sun gear in the pump broke, ill post pictures tonight when I get home.
Old May 11, 2012 | 07:40 PM
bruno2's Avatar
bruno2
Cool! If you cant find one let me know. I have the pump still . If they cost an arm and a leg let me know.
Old May 11, 2012 | 11:28 PM
Stangrcr1's Avatar
Stangrcr1
What does the pump housing look like? Bet it is chewed up from the parts floating around.
Get Bruno's pump or a rebuilt one.
And what does the converter shaft look like?
Old May 12, 2012 | 03:19 PM
goofy3392's Avatar
goofy3392
The pump housing looks ok, the gear just broke then jammed against the outer gear. You can see gouging on the inner gear from the converter shaft.
Old May 12, 2012 | 03:35 PM
goofy3392's Avatar
goofy3392
Old May 28, 2012 | 01:29 AM
goofy3392's Avatar
goofy3392
Hey guys, just wanted to give an ending to this thread.
I bought new gears for $16 and I had a bushing from the rebuild kit and installed everything the correct way, and the transmission finally works! Thank you all for your opinions, very much appreciated.
Old May 28, 2012 | 01:59 AM
Stangrcr1's Avatar
Stangrcr1
Looks like the inner gear was cracked on the other side too.
Also looks like some galling marks/hot spots. Did you measure the pump clearance with the new gears?
Congrats on fixing it.
Old May 28, 2012 | 06:30 AM
82f100460's Avatar
82f100460
thanks for the update!!! got that TC ingaged correctly this time
Glad you got it fixed...for a few dollars it looks like, and a lot of experience
Old May 28, 2012 | 07:26 AM
  #28
Gary Lewis's Avatar
Gary Lewis
Yes, congrat's! Thanks for the followup. It is good to hear of a happy ending.
Old May 28, 2012 | 07:33 AM
  #29
bruno2's Avatar
bruno2
Thats good to hear Goofy. Sorry the shipping was so high for the parts I had. Sounds like you found a smoking deal and got her back on the road.
Old May 28, 2012 | 12:04 PM
  #30
goofy3392's Avatar
goofy3392
No problem bruno, I didn't realize how heavy that TC was.
And I didn't check the clearances, Stangrcr1, I don't think it mentioned it in my manual but I did compare the gears first, and they looked identical although I didn't have my caliper. And yes the inner gear was cracked on the opposite side as well, but I could not see any damage to the pump and there was just a small bur on the TC that I filed off.
Yes, lots of experience learned here, I've been working on that truck for 3 months or so now, probably ever other weekend or so. Drove it home last night. Nothing like driving a good ole truck like these.
I got the new gears from this website if anyone ever wants to know in the future
C6 Transmission Parts & Rebuild Products
I bought the truck for $300
Rebuild kit, supplies and new gears I spent about $200 there
