fuel leak help
Old Apr 28, 2012 | 06:49 PM
renoduckman's Avatar
renoduckman
fuel leak help
My 02 has a fuel leak. I can see it sitting on top of the engine. 2 years ago a local diesel shop fixed a leak that was the o rings on the drain valve. Is it possible the same thing is leaking again? Any tricks on how to pin point what is leaking?
I know this will sound odd but i have had some side effects from an eye surgery i had and i just am not seeing as good as normal. I appreciate any help. Joe
Old Apr 28, 2012 | 07:16 PM
Bonanza35's Avatar
Bonanza35
If its the fuel bowl, just remove it and rebuild the whole thing. Its easy and dosen't take long. Call Clay or Bob at diesel 0-rings.
Chet
Old Apr 28, 2012 | 08:09 PM
F350-6's Avatar
F350-6
Depending on what kind of o-rings the shop used, it could easily be the same drain valve o-rings again. You can replace them yourself with these Replacement O-rings for Ford Diesel Engines
There are instructions on that page with pictures that show you how to change them.
disneyd
Feb 9, 2015 11:19 AM
jacob_powerhouse
13
Nov 22, 2011 09:12 AM
malodin
17
Nov 24, 2010 06:01 PM
desert sled
Dec 5, 2009 08:13 AM
k2vailkid
Oct 25, 2008 09:48 AM
