Adding Cruise Control
  #121
Old 03-11-2018, 10:59 AM
EllieMae94's Avatar
EllieMae94
EllieMae94 is offline
It looks like you do have the connector for cruise. Its that gray connector in the center of your pic. Hopefully somebody else on here can confirm.
  #122
Old 03-11-2018, 11:16 AM
Ruckin69's Avatar
Ruckin69
Ruckin69 is offline
Cruise
Just to clarify that wires coming from underneath and not at the Y. Although it does appear like it is it is an illusion from the picture. Here's some more pics
  #123
Old 03-11-2018, 11:39 AM
EllieMae94's Avatar
EllieMae94
Yes, I think you and I are both in luck! I think the grey one is the connector to the brake master cylinder. Of course, you need the correct master cylinder for cruise. The connector that's attached to your driver's side fender is the one that goes to the servo. Yours is to the left of the EEC tester and comes from that "y." It measures about 2 1/4" by 1/2" wide. Mine was tucked so far under the fender I didn't see it until today. If nobody else here can attach pictures of an operational cruise setup I'll take pics tomorrow of one at a local junkyard.
  #124
Old 03-11-2018, 11:41 AM
Ruckin69's Avatar
Ruckin69
Ruckin69 is offline
Cruise
In this thread people have used a jumper so they don't have to swap out Master cylinders. Is that correct?
  #125
Old 03-11-2018, 11:43 AM
EllieMae94's Avatar
EllieMae94
Yes, that is correct. I think they use a spare spout connector.
  #126
Old 03-11-2018, 01:19 PM
Ruckin69's Avatar
Ruckin69
Ruckin69 is offline
Cruise
Looks like it should be pretty straight-forward then. Swap it out. Does anyone know what these connectors are for?
  #127
Old 03-11-2018, 04:12 PM
EllieMae94's Avatar
EllieMae94
The one in the first pic is the spout connector.
  #128
Old 03-14-2018, 05:28 PM
Ruckin69's Avatar
Ruckin69
Ruckin69 is offline
Cruise
Any updated pics from anyone?
  #129
Old 03-15-2018, 12:02 PM
EllieMae94's Avatar
EllieMae94
Ok, these pics were taken off a '94 F1-50 with a 302:
This is the connection at the master cylinder (recall part). In that bundle of wires is a black square connector that connects to the recall part. On my '94 XL non cruise equipped truck that connector is attached to the side of the Power Distribution Box (see pic below).
Here's the connector to the servo. Notice it's the large connector coming from the "y." This connector is attached next to the EEC-IV tester on drivers side fender.
Servo part# F4TF 9C735 AB
Photo of my truck w/out cruise control. Notice black connector on side of power box. This is the connector to the recall part that leads to the master cylinder.
  #130
Old 03-16-2018, 05:30 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
You need a master cylinder for cruise as well
  #131
Old 03-16-2018, 09:07 AM
Ruckin69's Avatar
Ruckin69
Ruckin69 is offline
In this thread they said you can bypass a new master cylinder. Are you positive about that last post
  #132
Old 03-16-2018, 09:53 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
Originally Posted by EllieMae94
Ok, these pics were taken off a '94 F1-50 with a 302:..
Is this a junker or running?
If it was near me, I'd strip it like like one of them cartoons of ants/termites that leave nothing but sawdust.
  #133
Old 03-16-2018, 09:59 AM
EllieMae94's Avatar
EllieMae94
It was a junkyard truck. I took the servo and cable from it for myself.
  #134
Old 03-16-2018, 10:57 AM
Scndsin's Avatar
Scndsin
If it was an E trans, that ECU & harness would be choice for a MAF conversion for a 5.8
  #135
Old 03-17-2018, 04:21 PM
Diesel_Brad
its been a couple years, since I added it in my bronco, maybe you dont
Quick Reply: Adding Cruise Control
