Sponsored by: Real Truck
Installed gauges --- PICS
Old Apr 27, 2012 | 01:43 PM
grec-o-face's Avatar
grec-o-face
So, I've never liked the AutoMeter pillar-pod unit. Always thought it was bulky, kinda chunky looking. Back in my Mustang days, I ran a SOS pillar pod. There's nothing like it for our SD's, so I made my own. Hope you like it.
I used standard AutoMeter cups (for 2-1/16 gauges). I wrapped the edge of the gauge a few times around with electrical tape to create a "friction fit" into the cups. (My Aeroforce has been mounted this way for a long time with no trouble)
Marked them out where I wanted em, drilled some holes and rivited them to the factory A-Pillar. I found a VERY CLOSE to matching paint at Lowes for the cups. The wires (or lines) have to run out the back of the cups and into the pillar, I'm planning on covering the exposed harnesses and boost line with some loom or vacuum hose --- I'll get there.
Overall, I'm pretty happy with the results.
A few things I would do differently if I could re-do them; I'd mount the cups with the openning slit on the very bottom (I clocked mine too far around and the boost gauge fittings cause the gauge to be mounted at an agle. Also, I'd mount the cups about 1-1/2" lower on the pillar.
Some of the pics show the first one I did on the column for my Aeroforce Interceptor.
Only thing left to do is wire them up!
Old Apr 27, 2012 | 01:47 PM
grec-o-face
If you can't see em, they're Boost and Pyro. Autometer GS series. Powered/night pics will follow - but may take some time.
Old Apr 27, 2012 | 02:31 PM
MikeC501's Avatar
MikeC501
look's good to me.
Old Apr 27, 2012 | 02:44 PM
cbzdel's Avatar
cbzdel
do they bounce around much on bumpy roads?
Old Apr 27, 2012 | 03:31 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Looks pretty good
I would've tried that first before doing my 4 pod pillar
Old Apr 27, 2012 | 03:51 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Thumbs up
Looking Great Grec-o
I bet that saved a million dollars
Old Apr 27, 2012 | 04:19 PM
grec-o-face
No bounce. Pretty solid actually.
Thanks.
Probably the same cost as the Autometer Dual pod pillar, but I like mine better.
Old Apr 27, 2012 | 06:19 PM
Airborne1's Avatar
Airborne1
Looks pretty good! Great job on them!
Old Apr 27, 2012 | 06:54 PM
dkf's Avatar
dkf
What color (or part #) is that paint called? Matches pretty darn good.
Old Apr 27, 2012 | 06:57 PM
grec-o-face
It's rustoleum's Gloss Khaki. I couldn't find it in satin. I just brought the pillar in to Lowes with me and found the closest one.
Old Apr 27, 2012 | 07:19 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Looks great! Very clean install. Reps!
Old Apr 27, 2012 | 08:04 PM
grec-o-face
Thanks!!
Old Apr 27, 2012 | 09:21 PM
dkf's Avatar
dkf
Thanks.
Old Apr 28, 2012 | 07:21 AM
hanklin's Avatar
hanklin
yes!!! I second that. Great job
Old Apr 28, 2012 | 07:40 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
Looks great. The only suggestion that I would have is to add reinforcement behind the rivets if you didn't. I would imagine that over time the pillar plastic could or would crack if not reinforced.
