TJBeggs IC writeup?!?
Old Apr 25, 2012 | 01:55 PM
Awitte58's Avatar
Awitte58
Question TJBeggs IC writeup?!?
Hey People keep saying for IC writeups that Tim has the best one to referance.
Is that Tim that is linked in the 'tech mod' sticky?
Or TJBeggs... cuz I looked at his page for threads he started and cant find it
Just curious if anyone has the link. I know of TJ's e-fuel writeup.. but cant find the IC.
If not i can git r done with the other ones I have found.
Old Apr 25, 2012 | 02:05 PM
Talyn's Avatar
Talyn
I have a lot of how too links saved and none of them are for Tims IC writeup.
I dont remember him doing one though.
Old Apr 25, 2012 | 02:10 PM
Awitte58's Avatar
Awitte58
Fair enough. The "Tim's IC" was linked in the tech mods so maybe that was the one I was thinking of.
My bad.
I like reading through 3 or so writeups to see what was different between them and the problems they ran into. Some people had 0 problems with mounting and cutting holes.. so had issues with it fitting.
Just interesting things that will make my project go that much smoother.
Old Apr 25, 2012 | 02:42 PM
Talyn's Avatar
Talyn
If you have a welder and some steel to bend and weld to make brackets, the IC installs are easy.
If you don't have these things, then its tough.
Old Apr 25, 2012 | 02:47 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Yeah if you have cutting/welding skills, it's an easy job. Just takes some time is the biggest problem. Took me 2 days to get mine mounted and the front end back together and another night of work to fab the IC pipes.
Old Apr 25, 2012 | 04:35 PM
fordpride's Avatar
fordpride
I have a full 7-9 hrs. in mine
Old Apr 25, 2012 | 05:04 PM
Awitte58's Avatar
Awitte58
Hmmm good stuff. Yeah I have a small-ish Mig style welder. and a 10gallon compressor for a cutting wheel.
Should be do-able.
Biggest PITA is having only a driveway to do it all in so it sits out in the weather apart.
For an IC it aint that bad, but when doing injectors...GPs...or anything internal I really hate it.
Old Apr 25, 2012 | 05:27 PM
fordpride's Avatar
fordpride
This works real good. It's what I used on mine
chain pipe cutter - Product Details
Old Apr 25, 2012 | 06:11 PM
Awitte58's Avatar
Awitte58
Well I got a set of aluminum welded pipes with an all aluminum IC for $150.
They were from an SD of course... the pipes were off an 2000 and the IC was obviously a 99.
Need to get the boots/clamps though... Does Clay have the kit..?
Old Apr 25, 2012 | 06:37 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Here are some pics of him about IC retrofit, maybe helps you
Webshots, the best outdoor photos!
Old Apr 25, 2012 | 06:54 PM
strokin'_tatsch
Clay should have all the boots/clamps you need. If not, I know dieselsite does.
Old Apr 25, 2012 | 07:02 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Here's some few links to do this project:
Tims I/C Page example
https://www.ford-trucks.com/forums/95...ll-pt-1-a.html
6.0L intercooler install in '92-'96 body
Old Apr 25, 2012 | 07:07 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Yep, we have all of them that you need. Just let us know.
Old Apr 25, 2012 | 07:14 PM
strokin'_tatsch
Just checked your website. Your prices on the IC boots are awesome!!
Old Apr 25, 2012 | 07:53 PM
Riffraff Diesel
PREMIUM SPONSOR
Thanks, we try and keep them as low as we can on a Made in the USA product.
