My Coolant Filter Install/Write up
Old 05-19-2012, 11:35 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
Does it makes sense to run the output of the filter into the degas bottle so you can see how much flow is/isn't happening?
  #77
Old 05-19-2012, 11:50 AM
richdawg's Avatar
richdawg
richdawg is offline
Someone on here was doing that, I'm not sure if it"s a good idea or not. It does sound interesting though.
  #78
Old 05-19-2012, 11:57 AM
richdawg's Avatar
richdawg
richdawg is offline
Originally Posted by redman84
SCA = Supplemental Coolant Additive
DCA = Diesel Coolant Additive
I am confused as usual.
If the DCA is for Diesel, what is the SCA for, it's the one that is talked about most here (SCA strips to test SCA)etc. ?
  #79
Old 05-19-2012, 04:50 PM
redman84's Avatar
redman84
redman84 is offline
I've been led to believe it's two names for the same thing. Maybe someone will chime in with a huge breakdown of it if there's a difference though.
  #80
Old 05-21-2012, 07:09 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
Same stuff, just being called by two different names. Get it from Ford, or get it from NAPA. I got mine at NAPA they call it NAPA Kool. Here's a link. The 2 quarts was enough to charge 8 gallons or so of new coolant and have plenty left over to keep me topped up for the foreseeable future. The 2 quart bottle is definitely the way to go since it only cost about as much as two pint bottles would have -- $22 for the 2 quart (4 pint) bottle or $8 a pint. Here is a link:
NAPA AUTO PARTS
  #81
Old 05-21-2012, 09:45 AM
Awitte58's Avatar
Awitte58
Awitte58 is offline
Thank goodness Im not going crazy.
I thought i had been reading the entirely wrong thing for a while now lol
I guess if either works ill just get either.
meh ill worry about it when i come to do it.
  #82
Old 05-21-2012, 10:19 PM
baker1983's Avatar
baker1983
baker1983 is offline
Is napa calling this a fuel filter head rite or am i wrong thanks
  #83
Old 05-22-2012, 02:33 AM
richdawg's Avatar
richdawg
richdawg is offline
Napa calls this one a coolant filter kit P/N 4019 (no filter).
P/N 4070 would be the coolant filter with no additive charge added.
  #84
Old 05-22-2012, 02:40 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Ford4Life7.3 is offline
i believe it is called a coolant filter. The part number is 4019
  #85
Old 05-22-2012, 06:34 AM
DIYMechanic
For what it's worth the website calls part number FIL 4019 a fuel filter base. For some reason I can't view any of the product images on their site right now though so I can't match the pictures...
  #86
Old 05-22-2012, 08:41 AM
baker1983's Avatar
baker1983
There site shows the same base just says fuel filter base i just want to make sure im getting the rite stuff when i do mine
  #87
Old 05-22-2012, 08:46 AM
DIYMechanic
I doubt they have two different filter bases with the same part number. I think that's the one you want!
  #88
Old 05-22-2012, 10:52 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Wink
here you are
NAPA AUTO PARTS
  #89
Old 05-22-2012, 01:08 PM
DIYMechanic
Yeah that's the same site I was pulling up but for some reason I don't see a picture of the product. At any rate, it sounds like that's the one you need.
  #90
Old 07-19-2012, 01:29 PM
baker1983's Avatar
baker1983
Originally Posted by Ford4Life7.3
So i guess its about time for me to put something back into the site other than my opinions! So here is my write up on how i installed my coolant filter! So here it goes
What you need:
Filter head kit Napa PN: 4019
Wix Coolant Filter PN: 4070
4" of angle iron
Drill bits/drill
Heres what i started with.
I cut it down to size, did some painting and mounted the filter head and filter on to the angle iron. It should look something like this
I used teflon tape around the fittings and tightened them down pretty good. I was worried about over-tightening them at first, but once i hooked it up it leaked a little and i ended up having to retighten them.
I chose to mount the filter off of the alternator like so
Mark the locations of the two bolts on the alternator on your angle iron, and drill the holes so you can put the alternator bolts through to hold the bracket youve made.
Heres how i routed the hoses:
Its been about 2 months now since ive added the filter, so i figure it should be time to change it when i do my next oil change. When i do, ill cut it open and see what kind of stuff it has fished out of the motor. Should be good to see. Hope this helps someone.
NOTICE: The first time i did this i routed the hoses wrong, but i fixed all the information in the above write up. So don't be confused the comments about what was to be fixed as its been taken care of.
So the last pic is the correct way to run the hoses ??
Quick Reply: My Coolant Filter Install/Write up
