My Coolant Filter Install/Write up
Old 04-25-2012, 03:03 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Ford4Life7.3 is offline
Originally Posted by 427 fordman
Did you look at the other thread I put some pics up for you when you asked on that one..
I just went and looked bud, those are the pics i needed!! Guess i shouldve read through it the first time thanks.
Old 04-25-2012, 03:15 PM
Talyn's Avatar
Talyn
Talyn is offline
You can see the hose routes here in this picture.
Old 04-25-2012, 04:04 PM
Ford4Life7.3
Thank you guys, getting it fixed then il edit my post haha!
Old 04-25-2012, 11:41 PM
Ford4Life7.3
I put the new pics of it on my original post. Please tell me i got it right now haha! Thanks for the help guys
Old 04-26-2012, 05:37 AM
427 fordman's Avatar
427 fordman
427 fordman is offline
Looks a lot better now Rob!
Old 04-27-2012, 06:40 PM
BlueMule's Avatar
BlueMule
BlueMule is offline
It looks to me like you still have it flowing in the wrong direction. The inlet should be supplied by the hose that comes from the head and the outlet on the top of the filter head should "t" into the hose that returns to the top of the water pump.
Old 04-27-2012, 06:43 PM
427 fordman
Maybe I should have looked closer, I just saw he had two tees and not full flow any more and thought it was right..
Old 04-27-2012, 07:27 PM
Ford4Life7.3
I have it routed the same way as Talyn does in this dont i?
Old 04-27-2012, 07:28 PM
Ford4Life7.3
I cant tell where that hose goes on his
Old 04-27-2012, 07:43 PM
427 fordman
The hose from the top of the housing goes to the pump return, the side hose is/should be the one from the head. If that's how it is you're ok, its kind of hard to tell for sure.
Old 04-27-2012, 07:51 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Exclamation
No, if you see both pics, the "T" in the Talyn´s pic (the only one you can see and goes to the water pump to the heather) goes at the top of the base filter and your goes to the side, as I can see.
Old 04-27-2012, 07:52 PM
Ford4Life7.3
Im out in the yard fixing it as we speak. Im a moron lol.
  #28
Old 04-27-2012, 08:02 PM
BlueMule's Avatar
BlueMule
BlueMule is offline
Rob
I wouldn't fix it yet unless you have a new filter to put on. Because it has been flowing backwards for the past several months any sediment that has been collected will be in the center tube of the filter instead of trapped in the pleats. Once you hook it up the right way all that junk will be washed out of the filter and back into the water jacket.
  #29
Old 04-27-2012, 08:08 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Originally Posted by BlueMule
Rob
VERY GOOD call Rodney, I hope he read this right now.
  #30
Old 04-27-2012, 08:29 PM
Ford4Life7.3
I did! I have to run to oreilly for hose now anyway lol
Quick Reply: My Coolant Filter Install/Write up
