15 degree EOT/ECT delta an absolute rule?
I would say your readings are most normal, as long as it goes down after working it hard. Your ECT will vary much faster than EOT. From what I understand, this is totally normal looking at the size of the radiator, plus the sensor is right beside the thermostat, lots of fluid going through there, As for oil coolant, the coolant has to wiggle it's way through oil cooler and then through the EGR, heat exchange cannot be has quick with the warm oil.
My ECT is always colder in cold weather, 184 to 188, it varies. In warm weather it will go up to 190 to 194.
Time will NOT correct this issue. You most likely have a plugged oil cooler and need to fix the problem before you roast your engine.
Maybe in a Round about way it will^^
Once the Oil Cooler gets Pushed to Far or To LONG it will Burst and Must be Repaired
Time will Make things More Expensive to fix for Shure
Time Along wont fix it
Just Saying LOL
300 EOT`
I know this post is years old, but seemed to be a good one to post. i just got a scangauge, and i plugged the code in for EOT, and it was mesuring 305*, that seems to high. if it was that high i dont think the truck would be running correctly.
My truck was running just fine, no problems not CEL, so i think have wrong code in there.
My truck can run 200 ECT - 215 EOT at 75 mph, empty. It takes a while to get there. I think what is confusing about all this is that the temperatures can vary a lot depending what is going on. It would be nice to know how a oil cooler degrades over time. I mean dose it slowly degrade or can there be a jump in deltas. Mine seems to be degrading with time but I think I am good for now. If my EOT ever reads 230 I will become concerned.
I bet you will find an error in it. 300º is a tad high. Tad as in it's enough
to melt the filter stand pipe and it would not be running very well after that.
One thing to look at with the Delta ∆ is recover time. High ∆ and quick recovery
time and you may still be ok. It's when your recovery time gets really long
that you should be looking into things.
Sean
You have the settings wrong in your scangauge...........
I have an 05, 6.0. I had the dealer replace 2 oil coolers they flushed out the system twice each time with VC-9. I had the dealer install new head gaskets and install ARP head bolts, they put in the EGR delete. I installed the IPR oil cooler bypass system that puts the oil cooler external to the block, external coolant filter. I run the gold antifreeze recommended for this engine, I run ful syntedic Amzoil, I replaced both the EOT and the ECT sending units. My temps run ECT 198 EOT 258, there has to be another reason besides the oil cooler or flushing the system. I was wondering about the check valve under the oil filter or maybe water pump
#28
Have you verified that the sensors are reading correctly?
If you have not done so then after an 8Hr cold soak check the
ECT,EOT and TFT they should all 3 be about +/- 2ºF.
Now that you have put an external cooler and filter on it. You
are going to see a different ∆ (delta) temp. Things to look at would
any restriction of coolant or oil flow to the cooler and returns back
to the engine. So this more or less will toss the standard out the window
The cooler making the only real change to the ∆ temp.
But have a look at what I said to look at first. Also look at recovery
time, If the cooler is working and doing it's job the temps should
come back to there "new" normal fairly quickly. If not then it's time
to do some investigating.
Sean
EDIT : wording for clearer understanding. The ∆ is affected by the cooler
change not the addition of a coolant filter.
Sean
#29
#30
External coolant filter shouldn't affect the efficiency of the oil cooler. If your at 15* now, filtering the coolant won't help, the damage is already done... the issue is coolant flow through the oil cooler and if it's plugged, why the difference in temps. Low coolant flow leads to higher oil temps. If you are above 15* after the level ground for 15 minutes at 65mph test, you should consider an oil cooler replacement after a good chemical flush of the cooling system AND then adding the coolant filter to keep it clean.
Just for info... an EGR delete or adding an external oil cooler is what makes the spread of 15* not accurate/doesn't apply any longer. As the coolant exits the oil cooler (higher temps than normal) it cools the exhaust gases in the EGR cooler even less causing the rupture. If there isn't anything (EGR cooler) to rupture, it doesn't matter any longer. The coolant/oil temp spreads are not as critical... only 253 degrees at that point to cause the truck to go into limp mode and defuel the engine in an attempt to cool the truck. If the coolant isn't cooling effectively, then it's time to change oil coolers. If my oil was running say 230* all the time, I'd be concerned and towing even more concerned about the 253* mark when working the engine hard.
