Rich? Or false!?
Old Apr 23, 2012 | 07:04 PM
bob8619's Avatar
bob8619
Rich? Or false!?
1995 F150 5.0 here. KOER test is saying the beast is running rich, right side (code 173) however exhaust smells nothing like gas and there isnt any smoke so my question to you experts out there, can an engine run rich without smoke or gas smell? Or is it a wacked out o2 sensor by chance? Let me know if any added info is needed.
Old Apr 23, 2012 | 11:51 PM
bucks150's Avatar
bucks150
Ive seen mine blow smoke and never throw a code so I don't see why it couldn't say it was rich and not be I'd try and atleast take the O2 sensor out and see what it looks like you might be able to clean it or for around $40 you can get a good Bosch to replace it with. They are supposed to be changed every 60k mi anyway. By the way this is jrh5610 off of f150forum.
Old Apr 24, 2012 | 12:41 AM
Evan_P's Avatar
Evan_P
Hook a fuel pressure gauge up to it at the rail and see what the pressure is...
Old Apr 24, 2012 | 07:18 PM
bob8619's Avatar
bob8619
What should the pressure be?
Old Apr 24, 2012 | 08:07 PM
Evan_P's Avatar
Evan_P
For V8's around 39psi. Any higher than that, you need to check the FPR for leaks...
Old Apr 24, 2012 | 08:11 PM
bob8619's Avatar
bob8619
Ok. Just in case you can add anything else heres some updated info. New ECT sensor, new oxygen sensor, new air filter. No CEL but when I run the KOER test it gives me the rich code. Since replacing the air filter the code will alternate between the rich code 173 and some code 331, never both at the same time. Also I checked the plugs and they are all white no sign of rich running.... So confusing to me.
Old Apr 24, 2012 | 08:38 PM
White 97 xlt's Avatar
White 97 xlt
Have you cleared the codes since you changed all those parts???
Old Apr 24, 2012 | 08:40 PM
bob8619's Avatar
bob8619
Yeah even after changing the air filter. Am I wrong in thinking that at the very least I should see some fouled up plugs if it was indeed running rich? the code has been there for at least a month
Old Apr 24, 2012 | 10:53 PM
Nick_lebbad's Avatar
Nick_lebbad
you have cats.. if they are doing their job you wouldn't smell fuel depending on how rich it is running.. my exhaust smells like fuel all the time.. no cats and running a little rich..
dj8667
Mar 7, 2005 09:56 PM
Wakeboarder141
34
Aug 4, 2004 11:28 AM
POTBELLY
Dec 18, 2003 01:12 AM
gtuma
Jul 30, 2002 06:16 AM
