Fuel tank issues
Old Apr 23, 2012 | 05:26 PM
Badbart's Avatar
Badbart
Fuel tank issues
I'm new here. I have a 1997 F350 Crewcab longbed dually that has been great up until recently. The fuel gauge on the front tank quit working some time ago but I put off fixing it. Last month a leak in that tank developed so i figure, OK, I'll replace the sending unit when I drop the tank to see what the cause of the leak is. Well, the tank's rusty, has a pinhole in it. I looked at the sender and it's attached (welded?)to the tank pickup tubes....The sender has a bracket with holes for mounting. But there is nothing on the pickup tube to mount to....?!? Has anyone had this issue? I contacted the Ford dealer and was told this part(the pickup tube) is no longer available. No aftermarket pickup tubes are available. Any suggestions?
Old Apr 23, 2012 | 05:33 PM
Devore95's Avatar
Devore95
It sounds like you will be making a junkyard visit
Old Apr 23, 2012 | 05:55 PM
Ken_C's Avatar
Ken_C
I would look into those titan tanks. made of poly to be rust proof. I think these could be made to fit an OBS.
http://www.titanfueltanks.com/images...-w-caption.jpg
sure wish one of you would foot the bill for one of these so I can see for sure that they can be made to fit our trucks.
Old Apr 23, 2012 | 06:01 PM
Ken_C's Avatar
Ken_C
if not i think rock auto sells the stuff you need. youre looking for rock auto part number PS20 i think. they also sell the standard midship tank.
Old Apr 23, 2012 | 06:03 PM
Badbart's Avatar
Badbart
Yeah, I've been looking at those custom aftermarket tanks. I don't want to spend $1400.00 on a fuel tank, even if it does hold 51 gallons. I had thought of installing an auxilary tank but they have to be run through the existing tank(to be DOT compliant)....so I'm back to square one?@!#$
Old Apr 23, 2012 | 06:16 PM
Ken_C's Avatar
Ken_C
Are you running a comercial rig? if not I wouldnt worry about DOT. an in bed aux tank could be plumbed directly to the tank selector valve. or do you have to get it looked at as a precondition for your registration? theres always transferflow. their tanks have electric pumps and you could plumb it to the rear tank?
Old Apr 23, 2012 | 06:53 PM
Badbart's Avatar
Badbart
I'm going commercial. Hauling new RV's from Indiana. I have to get a DOT inspection too. I'm looking into the junk yards but not getting a lot of cooperation. One of them told me that, yes, they did have a 97 F350 in their inventory but they did not know if it even had a fuel tank. Whatever happened to the wreckingyards having a network to find the parts you were looking for?
Old Apr 23, 2012 | 07:10 PM
Ken_C's Avatar
Ken_C
Honestly I would think that a 16 year old tank is going to be 16 years old and not in too good of condition weather its under your truck or in a junk yard. i would try rock auto thats where people here go for the big 38 gallon rear tank mod.
Old Apr 23, 2012 | 07:17 PM
Badbart's Avatar
Badbart
I have a new midship tank coming tommorrow. It's the pickup tube with the aforementioned attached sender that i can't locate. This is the first I've heard of a 38 gallon rear tank though. Tell me more. Do you have to remove the spare tire? Also, are us newbies unable to send a PM?
Old Apr 23, 2012 | 07:28 PM
Ken_C's Avatar
Ken_C
Check it: Performance Injectors for 7.3L Ford Power Strokes
Also check this https://www.ford-trucks.com/forums/1...ostic-faq.html
I think you need at least 25 posts to do most thing other than post a new thread.
Old Apr 23, 2012 | 07:42 PM
Badbart's Avatar
Badbart
Thanks for the help!
Old Apr 23, 2012 | 09:12 PM
Badbart's Avatar
Badbart
I got your message but I can't PM you. Thanks man! I'm in Tallahassee, Florida. the tank in question is the front, or midship tank. It's a 19 gallon steel tank. I think it's 59 inches long if that helps. I have a new tank coming but the pickup tubes with the connected sending unit is what I can't seem to find. Any help is greatly appreciated..
Old Apr 23, 2012 | 09:29 PM
bad12jr's Avatar
bad12jr
www.car-parts.com
Great site. Found alot of parts here.
Old Apr 23, 2012 | 09:38 PM
Badbart's Avatar
Badbart
Originally Posted by bad12jr
www.car-parts.com
That's great! Thanks for the tip!
Old Apr 23, 2012 | 10:18 PM
ReBilld's Avatar
ReBilld
I priced these tanks a couple years ago. Seems like they were about $160
MTS COMPANY, L.C. - Ford Pickup fuel tanks
