Injector codes?
Old Apr 23, 2012 | 10:51 AM
Shattered's Avatar
Shattered
Injector codes?
I have a 99.5, and I have an opportunity to buy a set of injectors to use as cores for 200$. My question is what is the difference between them as far as
AA
AB
AD
so on and so forth?
Old Apr 23, 2012 | 11:38 AM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
go to RIFF RAFF's site, look for injectors, its all listed there.
Old Apr 23, 2012 | 12:36 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Riffraff Diesel: New Alliant Stock Injectors
Injector Description:
AA - '94-'97 Non-California trucks. They are all 90cc injectors and are single shots.
AB - '97 California, and all Early '99 trucks. Split Shot injectors that flow 130cc of fuel.
AC - Came in high torque version of the T444E and didn't come in any Powerstrokes. They have the same internals as the AB injectors with the exception of the single shot plunger and barrel and are 160cc.
AD - These are found in all late '99-'03 Powerstrokes and T444Es, and are a Split Shot Injector
AE - Long lead AD injector that was used to cure a "cackle" issue.
Old Apr 23, 2012 | 01:30 PM
Shattered's Avatar
Shattered
when it comes to cores, do they need to be the same code as your truck? or does it matter since they are being rebuilt?
Old Apr 23, 2012 | 03:57 PM
429 f-100's Avatar
429 f-100
clay took my ab cores for the ac's i bought from him! great guy to deal with
Old Feb 8, 2023 | 01:23 PM
Conebread's Avatar
Conebread
5th Gear
I have a question mainly for the more experienced injector builders here but any knowledgeable/ straight to the point answer will be greatly appreciated.
Is there a difference between the AA (standard/single shot) & AC (standard/single shot) plunger and assemblies? Or is the difference in the CC rating of the two strictly due to the difference in the length of their intensifier pistons?
Asking because I am starting with AD's that I want to convert to single shots. So far it seems like the stock intensifier pistons in the AD's will have them flowing way too much fuel for my stock everything else no matter which p&b assembly I use.
Edit: How do I delete a post? I posted on this thread on accident.
Old Feb 9, 2023 | 02:47 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
@Y2KW57 can delete this post.
But aside from that sounds like a great new post in this forum, so have at it bro.
So you want to rebuild the injectors yourself rather than send them out?
mgraveman
Apr 14, 2016 09:28 AM
ltl_jrw
Jun 27, 2011 11:29 PM
GreatWhite99
Jan 1, 2009 04:32 PM
