What Rearend Do I Have? '91 F350 4 X 4
I bought a used '91 F350 Crew Cab 4 X 4. It has a 460 if that makes any difference. I'm trying to figure out what rear end is in it. I don't see any fill or drain plugs at a quick glance. The tag has the following in upper left of tag V132C Bottom left looks like 4L 10 bottom center of tag 10 2 Bottom right of tag 0H31
How do you tell a sterling from a Dana 80? Thanks for any help!!
4l 10 means that you have 4:10 gears with a limited slip.
You should have a Sterling 10.25. IIRC, the dana 80 was only in the f super dutys.
But by looking at it, the sterling cover is very square in shape, and the dana 80 cover will be diamond shaped. Do a quick google image search on the two if your not sure.
gofastl
09-07-2010 09:24 PM
DirtStripHero
03-07-2009 03:14 PM
quehele
03-20-2006 06:58 PM
