JACKS AND HORNS
Old Apr 21, 2012 | 07:20 PM
oldmerc's Avatar
oldmerc
oldmerc
Question JACKS AND HORNS
What did these trucks have for Jacks originally and what kind of horn should I install .I never toot the things but apparently I need one .
Old Apr 21, 2012 | 09:19 PM
oldmerc's Avatar
oldmerc
oldmerc
OK I think I get It . But I am wandering what the trucks came with for a jack .
Old Apr 22, 2012 | 12:12 AM
51PanelMan's Avatar
51PanelMan
There was a discussion about the Bonus Built truck jacks when "Julie" was still around. The conclusion made was that the jack was a hydraulic bottle type that screwed down into the floor near the fuel tank. The same jack was used for several decades later and is still similar to most bottle type jacks found in Ford Ranger pick up trucks.
Old Apr 22, 2012 | 08:45 AM
South of BC's Avatar
South of BC
Two articles I found:
https://www.ford-trucks.com/forums/9...a-picture.html
https://www.ford-trucks.com/forums/8...-location.html
Old Apr 22, 2012 | 09:12 AM
oldmerc's Avatar
oldmerc
oldmerc
Thanks for the info . It makes sense that things like radios heaters and jacks were supplied at the dealer . Still a common practice at Ford truck dealers .
Old Apr 23, 2012 | 06:31 PM
49m47's Avatar
49m47
If you go into my pictures you can see my jack. Apparently the jack was also used to set the camber when doing a front end alignment. Ive never done it but one of the books I have showed it being done. The jack has kind of a flip over top.
Old Apr 24, 2012 | 07:42 AM
oldmerc's Avatar
oldmerc
oldmerc
Thanks 49m47 . I went through your pictures and I may be able to find a similiar jack.
By the way the last thing a guy from Alberta wants to see is pictures of snow you should be ashamed of yourself .LOL
Old Apr 25, 2012 | 09:12 PM
49m47's Avatar
49m47
I live in St. Louis Mo. but I bought the truck from a guy in Vulcan Alberta CA. That picture of the truck in the snow is actually one of the pics that he sent me while we were working "The Deal"
Old Apr 26, 2012 | 01:10 AM
old_dan's Avatar
old_dan
I have the stock jack that tucks into the well by the gas tank...it's not a bottle jack. I'll snap a pic when the rain clears & post it.
Dan
Old Apr 26, 2012 | 08:14 AM
5 Star's Avatar
5 Star
Jack
Oldmerc
The Jack that came with my 50 Merc was a bottle type Jack but not hydraulic, it was the crank type with the folding handle that had a coupler that slid over the handle to keep it in place, the handle that is.
The Jack was stored on the passengers side to the outside of the seat at reat. The base of the Jack at one corner had a hole in it to put a thumb bolt through that went into the floor, i believe it was a 5/16 thread.
This secured the Jack from moving around the cab, and I stored the folding handle in the tool box on top of the gas tank, hpoe this helps.
Old Apr 26, 2012 | 08:19 AM
5 Star's Avatar
5 Star
Horn
Oldmerc
Forgot about the Horn it was a single one that mounted in a verticle position on the driver's side up front in the grille section. The opening facing in a downward position.
Old Apr 26, 2012 | 04:43 PM
49m47's Avatar
49m47
I uploaded a picture of my horn to my gallery . I can get a better picture if you need it.
Old Apr 26, 2012 | 06:19 PM
oldmerc's Avatar
oldmerc
oldmerc
Wow that is one cool looking horn . I'll bet it sounds awesome . That may take some searching to find one that is functional . Thanks
Old Apr 26, 2012 | 06:37 PM
49m47's Avatar
49m47
Thanks I like it to. I don't know if its original or not. The sound isn't to impressive. I don't know if its the horn or that its 6 volt.
Old Apr 26, 2012 | 07:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The stock horns were mounted horizontally on the underside of the hood.
